Thread: K-2006 numbers and questions
    Jul 2015
    Mantua, NJ
    3
    Hi all, I can't get the calculator to work on my phone so if you could advise, I'd appreciate it! I'm a total newbie with a 15x48 Intex metal frame currently running 1000gph cartridge pump. My 2500gph arrived today but much to my surprise did not come with all the parts needed to install, so I had to order these parts (spending more on them than I spent on the pump!!!) and they won't be here for a few days. So I'm stuck with the crappy pump for now. I had a green pool for a few days and have been adding a gallon of bleach a day to tide me over until I got my testing kit today. I have the Kem-Tek granules coming Tuesday. I know I need to raise my CYA but what should I be doing in the meantime until the Kem-Tek arrives?
    CYA 0
    FC 3
    CC 0.5
    TA 110
    pH 7.4
    Thanks!
    Aimee
    Intex 15x48 4,440g
    Intex 2500gph pump (on the way!!)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,537
    Re: K-2006 numbers and questions
    Good job getting the test kit. Please which kit you got to your siggy so everyone knows you have it.
    Your numbers look okay. TA a little high but can be fixed easy enough once your water is clear.
    The pump/filter will not clear your pool. You need to SLAM. Here is the link.
    Pool School - SLAM - Shock Level And Maintain
    Here is the CYA/FC chart to show your FC goals to get that greeen GONE!
    Pool School - Chlorine / CYA Chart
    I hope this helps. Let us know how it is going.
    Kim
