Thread: Hayward pump and filter for 18x33 pool
    Jun 2015
    AR
    12
    Thinking of going with the Hayward 1.5 HP 2 speed Power-Flo Matrix pump (SP15932S) for my new pool. Any positive or negative feedback on this pump or the size of this pump for an 18x33 pool?
    Also can I pair it with a Hayward Pro Series 24 inch In Ground pool sand filter? The reason I ask is because it says in ground in the title of this filter?
    18x33x54 AGP (18,500 gallons) - Hayward Power Flo 2 Speed Pump - Hayward 24" Sand Filter - TF100 Test Kit
    Casey's Avatar
    SW PA
    10,463
    Re: Hayward pump and filter for 18x33 pool
    The pump is a great pump. As far a filters go, you want to get the biggest filter you can afford. The bigger the better as it will cut down on maintenance and cleaning.
    Orlando, FL
    690
    I think the pump will work but maybe you can find a Hayward sand filter for above ground pools.Pro-Seriesā„¢ Top Mount Systems | Hayward Residential and Commercial Pool Products
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
