Results 1 to 17 of 17
Thread: Intex pool bottom clean
    Jul 2015
    Oshkosh
    5
    We have a 16x52 intex pool with a 2000gph saltwater pump combo and unicel filter. It could be pool location, but we are wondering if it would be worth while to switch to a sand filter combo which seem to come with a 12" sand filter and 2000 to 2600gph pumps. The pool doesnt look to bad we get a lot of fine dirt that builds on the bottom, but for this should we switch filters or just get an aqua broom which should be better than the hose vacuum from intex. On another note would the small sand filter let us use a real pool vacuum and create enough suction?
    May 2015
    Killeen, Texas
    89
    Re: Intex pool bottom clean
    Yes that sand filter will allow you to use a real vacuum. It will suck the debris up no problem.
    Beens's Avatar
    Jul 2013
    Virginia Beach, Va
    1,171
    I have a pool blaster max vacuum and I love it.
    I have a sand filter and can use a regular hose and vacuum but since I got the pool blaster I always use that instead because it's more convenient and I don't have to worry about if I will have to backwash my filter after vacuuming.
    18' x 48" (42" water depth) Intex Metal Frame 6,700 Gallons
    Hayward Power-Flo LX 1.0 HP pump
    Hayward Pro Series S166T Sand Filter
    Original Intex Floating Skimmer
    Jul 2015
    Oshkosh
    5
    If i were to get one or the other. Recommendations? Is the sand filter going to make that much of a difference?
    May 2015
    Killeen, Texas
    89
    The sand filter for me is a beast. The filter suction alone is amazing. It allows my skimmer to draw so much more water from the surface keeping all the bugs and debris off of the surface of the water. The return has much better flow so the debris lower in the pool has allowed me to keep the bottom a bit more clean before I vacuum by suspending the materials into the water column to allow the filter to get them. The additional flow also allows for the addition of things like spray bars or fountains which are nice too. Also I was having to replace or clean my filter every few days with heavy use. I now clean my sand once a week with a simple backwash and it's rumored my $15 worth of sand will last me 5yrs before i will have to replace it. That alone makes it a no brainer for me.
    Jul 2015
    Oshkosh
    5
    Sounds like a sand filter is in store.
    Jul 2015
    Orlando, FL
    26
    Off topic, but what did you use to do your plumbing? Connectors and hose?
    25,000 gallon inground plaster
    K-2006 test kit
    Jul 2015
    Oshkosh
    5
    I actually replaced the skimmer and inlet eye with standard hayward replacements. I used 1-1/2 tigerflex hose.
    Jul 2015
    Orlando, FL
    26
    Thanks. How did you then connect that to your Intex pump?
    K-2006 test kit
    Jul 2015
    Oshkosh
    5
    Its been a few years since i did it, but looking at the connections the pump i had was the larger pump so it already came with 1-1/2 hose. One had a leak and i opted for better hose since i was changing everything. It looks like i took the original threaded ends off the intex hoses, then got an 1-1/2 pvc box connector and slid that through the threaded end so when threaded the flat part would seal with the pump. The it looks like a 1-1/2female to 1-1/2 male pvc adapter. After you stick the box connector through the threaded nut you then pvc glue the box connector to the female end of the adapter. This seals and still allows the nut to spin so you can tighten it to the pump, but its now one piece. Then the male end of your new connector you just slip the new hose over and clamp with a good stainless hose clamp. Been problem free for 3 years. Hope this helps.
    Orlando, FL
    690
    Quote Originally Posted by Jnz1 View Post
    Yes! That is all.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    May 2012
    Las Vegas, NV
    92
    I switch to a intex 3000gph sand filter and I haven't looked back. The pump they include is under powered and I was tired of washing off the cartridge filter. When I vacuum it's perfect with no lost of pressure.
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    Jul 2015
    Orlando, FL
    26
    Quote Originally Posted by latin_racer View Post
    I'm gonna get this when I use up all my cartridges for existing pump. How many returns and inlets do you have on your pool and are you able to leave inlets/skimmer on while you vacuum or do you still need dedicated suction?
    K-2006 test kit
    jmcdtucson's Avatar
    Jun 2014
    317
    I have the 2450 gph (which they advertise as 3000 gph when selling it).
    I used to just have the skimmer. But I added another inlet and it is FAR superior. The skimmer door used to get stuck and then my pump would suck air. With the extra inlet, that problem is completely solved and the system moves a lot more water.
    You'll love the sand filter.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    May 2012
    Las Vegas, NV
    92
    Quote Originally Posted by relliky2d View Post
    Below is a pic of my setup. When i'm done vacuuming I can turn on the other intake and turn off the skimmer valve. This avoids getting out of the pool and allowing me to finish up. Once done I turn back on the skimmer.
    K-2006 TEST KIT
    kne's Avatar
    Jun 2015
    Concord, CA
    135
    I know this is an old post, but it looks like you still visit TFP
    When adding the through the wall skimmer, did you have any issue with using your old inlet as the return? I just don't know if height makes any difference.
    18' x 48" Intex Ultra Frame AGP, ~6,500 gal
    Standard cartridge filter and SWG that came with the pool (soon to change!)
    Test kit will all the required juices and powders plus the stir monster
    Aug 2013
    south east Arizona
    200
    Quote Originally Posted by kne View Post
    I have the same pool as you - the original return location and fittings are fine. My only advice is try to put the skimmer where the prevailing breeze helps with the skimming - that is, wind towards the opening of skimmer. You will really like having a bigger pump/filter and a wall skimmer.
    somewhere around 6,800 gal 18 x 4 foot round Intex Ultra Frame AG, finished filling August 29, 2013. toy pump w/ "A" cartridge up and running next day --- July 2015 upgraded to Krystal Clear 3000 GPH pump and 16" sand filter --- May 2016 Intex auto cleaner and in July salt system and Hayward skimmer
