Results 1 to 8 of 8
Thread: Slight Haze While Swimming
    michaelrbanks's Avatar
    Sep 2014
    Cibolo, TX
    89
    I've been TFP since my pool was built. Water is nice, clear and beautiful when nobody is swimming but recently I've noticed when the water gets stirred up a bit by swimming, there's a slight haze. All chemistry seems great, no CC's or unexpectedly high chlorine demand and until it started getting really hot, I haven't fallen below FC for my CYA level (adjusting a bit tomorrow, now that I stocked up on bleach).
    Is this typical, or an indication of an early problem?
    16,661 gal IG PebbleTec w/ Spa; 60 ft2 Jandy DE filter, 2 HP Jandy Variable Speed pump; 2 skimmer; 400K BTU Jandy heater; Polaris Sport; opened 9/15/14; TF-100 test kit
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Slight Haze While Swimming
    I get a little hazy when I have a lot of swimmers and a lot of sunscreen. It clears up pretty fast though. What are your current numbers?
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Sep 2014
    Cibolo, TX
    89
    As measured this morning before daily balancing: FC 3; CC 0; pH 7.8; CYA 35; TA 75; CH 325
    domct203's Avatar
    Jun 2015
    CT
    3,592
    Quote Originally Posted by michaelrbanks View Post
    If you are assuming CYA at 35ppm because it was right between 30 & 40 the scale does not work that way. It's best practice to round up to the next level when your measure above 30ppm.
    With that said, a FC of 3ppm is the absolute minimum for a CYA of 40ppm. You should stay at or above the target of FC 5ppm.
    Have you tried vacuuming to waste to remove what might be settling on the bottom? When you brush does anything stir up and cloud the water?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    It would probably be good to bump your FC up 2-3ppm before or after big swim days, or both. Should keep it all clear.
    Sep 2014
    Cibolo, TX
    89
    Quote Originally Posted by domct203 View Post
    I do realize the CYA scale is logarithmic. It's more than 30, but less than 40, so a linear 35 helps me sleep at night. My set points for FC are based on a target of 40 CYA, so between 5 and 3 is where I tend to keep it.
    I don't have a waste port for vacuuming - everything goes back through the filter, and pool brushing, like flossing, is something I know I need to do, but haven't been very diligent about. I have recently seen some advice on how to boost vacuum pressure by diverting the suction to the skimmers, so I may try that this coming weekend, along with a good thorough brushing.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    I get the haze after 3-4 swimmers are in the pool some times.
    Just run the filter over night and it will be clear again in the morning.
    my pool was painted and the paint is old and a little comes off when brushing.
    Pretty sure thats what it is.
    Dolphin E10 Cleaning Robot.
    May 2013
    Fort Lauderdale, FL
    423
    Same here. If I brush the bottom, I get a little white cloud of "stuff" that puffs up. The particles are too small for the Polaris to pick up. After a pool party and water is pretty hazy- then the filter takes it out or it re-settles and is clear in the morning. I thank my guests for "stirring up" my pool so the filter can do it's job.
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
