Thread: CH Raising
    Mar 2015
    South Florida
    43
    CH Raising
    I am having an issue with CH raising. CH starter at 225 and almost 6 month later is at 425. Is this because of the new plaster? The only thing I am adding to the water is MA every 3 days to balance the PH. Any suggestion?
    Note:" Tap water CH is 75
    12K gallons, IG, Durazzo, Pentair cartridge filter, Jandy ePump JEP2.0 VSP , Pool started March 2, 2015, South FL
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: CH Raising
    Keep your pH down closer to 7.2-7.4 range to avoid scaling. Its a newer pool I take it?
    Mar 2015
    South Florida
    43
    Re: CH Raising
    Yes, almost 6 months old.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: CH Raising
    I'd say you're doing well. Curing plaster will raise CH. Evaporation and refill will also raise pH. You live in Florida where it rains. Grab as much rainwater as you can to dilute things. Just remember that CYA drops the same percentage as the CH is you pump out the overflow.
    Mar 2015
    South Florida
    43
    Re: CH Raising
    Thanks guys. I was thinking to close the skimmer when is raining and pump water from only from the drains, that way I can keep more rain water in the pool.
