Thread: PH or Alkalinity First???????
    Jul 2015
    severn md
    10
    ​My ph and alkalinity are both low. Which do I try to adjust first?
    2010 install 20 x 40 (30,500 gal.) inground vinyl liner. Hayward 1.5 hp variable speed pump. Hayward 30" 500 lb. sand filter. polaris 360. ultra armor mesh safety cover. originally used salt generator(zodiac duo clear)but no longer. Have well water.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,464
    Re: PH or Alkalinity First???????
    PH all the way! Get it up fast as a low PH will cause damage to your equipment. TA is the last thing you worry about.
    Kim
    How are you testing your water?
    Jul 2015
    severn md
    10
    Thank you. That's what I started with using borax but I started to question myself. We are draining and adding water a little at a time to decrease the cya and my fill water always has a lower ph. Using these methods is new to me and I and questioning the way I have always done things.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Yes, definitely PH first. Soda ash will raise PH and TA. Borax raises PH with not much TA increase.
    More on pool chemicals here, Pool School - Recommended Pool Chemicals
