Results 1 to 9 of 9
Thread: Still looking for answers
    Jun 2014
    Houston, Texas
    475
    Okay. So the scum continues. literally. We use bromine. We replaced ALL three filters, put in fresh water and we still have scum and foam on this new hot tub. we've changed the water out at least 5 times now since October. We dump fresh and clear in every night. We check the levels all the time. The bromine can be fine one day and gone the next. it's like a rollercoaster of scum....
    We can not use the tub for a week and it will have scum....sigh. Anything else to try? we've done spa perfect too. I wrote an email to the spa company -- surprise, surprise. no answer. we have scum balls in there. I think we've tried bleach....idk! but it is a serious pain!
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    Jul 2015
    South County, Rhode Island
    36
    Re: Still looking for answers
    Dear DMS, I am a newb here but from what I have read, the first thing they say to do is to decontaminate your spa with Ahh-Some. If you have already done this, then forgive me. I plan to do so myself when I get it home. Hope this helps.
    2015 Bullfrog 131 180 gal Spa Indoor, TFP bromine fed, Taylor K-2106
    2012 2500 gal. Round vinyl AG Pool, Hayward Easy Clear Filter System, chlorine
    1994 Rubbermaid 175 gal horse tub, still looking for advice on algae problem.
    Jun 2014
    Houston, Texas
    475
    I've never heard that. decontaminate it from what? it was brand-new when we got it....it's been doing it from the very beginning....
    19k SW IG
    Jul 2015
    36
    From my understanding, spas are wet tested at the factory. In most cases, all of the water is not completely removed from the piping, etc. This standing water can grow nasty things that are considered biofilm. I heard that it is in your best interest to decontaminate the spa right from the start with Ahh-Some. If you do not eliminate these nasties, they will continue to grow and be a hindrance as well as a health issue. They will eat up your sanitizer like crazy and you will have a hard time keeping a proper sanitizer level. Do not touch this crud with your hands.
    I have heard that spa cleaners are not as effective as using Ahh-Some. If you do a search for decontamination or Ahh-some on this and poolandspaforum, I believe you will find considerable information on this topic, as did I.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I'm not familiar with bromine tubs. Have you seen this guide?
    How do I use Bromine in my spa (or pool)?
    I have used chlorine in my tub for 18 months and am very happy with it, following this,
    How do I use Chlorine in my Spa (or pool)?
    I have not used ahh-some and I've only drained twice because it seemed like I should. One time to see if the tub water would heat my pool any. No, is the answer to that! But, many people talk about how great aah-some is. Maybe give it a try.
    Mar 2007
    San Rafael, CA USA
    12,082
    Lyd is correct. If you've never used Ahh-Some you're in for a big surprise, even from a brand new spa. Biofilms fairly rapidly develop in spas due to the high bather-load and warm to hot water temperatures. Even new spas have greases in them as well as frequently having biofilms from wet testing.
    Jun 2014
    Houston, Texas
    475
    Does this mean we have to change our filters too after this awesome stuff is put in? we just changed them
    19k SW IG
    Mar 2007
    San Rafael, CA USA
    12,082
    By reading the Instructions for Use on the ahhsome.com website you will see that you add the product to the spa, run it, and take the filters out and put them in the main area of the spa. So the filters get cleaned via the Ahh-Some but they do not need to be replaced. They are powerful surfactants, but are not harsh oxidizers or acids or other chemicals that would harm filters or other spa components. Think of them as very powerful soaps that remove grease, break up biofilm, and help remove anything stuck to spa surfaces (including pipes) or filters. You then dump the water and wipe the spa surface at the waterline to remove what comes out.
    Jun 2014
    Houston, Texas
    475
    Oh, that sounds great - I know, I'm a nerd. But getting rid of all that stuff in there makes me happy!
    19k SW IG
