Thread: New pump q: is it normal to see air in pump basket on low speed?
    MitchRyan912's Avatar
    Jul 2015
    Madison, WI
    338
    I just threw a new 2-speed motor on my pump's wet end, and since I'm new to this, I'm not sure if it is normal that I see a good bit of air in the pump basket when it's running on low speed? It's fine when it runs on high speed. Overall, it seems like everything is working better (skimming) or at least the same (water pressure coming back in the return), so there's that. It's just the low speed that I wonder about.
    2016 total pool rebuild thread: here. Pool: 26,000 gal IG vinyl liner (20'x40') in Madison, WI. Gear: ​Superflo VS, Triton TR-60 filter, 2" hi-flow MPV, & Raypak 266A heater. Testing: Taylor K-2006C. Manual chems: 12.5% NaClO liquid, granular CYA, baking soda, 31.25% muriatic acid.
    38,473
    Re: New pump q: is it normal to see air in pump basket on low speed?
    Seems to be a common occurrence. Mine does it too.
    Jul 2015
    venice, fl
    4
    Yes, this normal.
