Thread: Replaced a MPV and one threaded union is leaking
    Sep 2013
    Charleston, SC
    537
    Is it ok to remove the 1 1/2 inch threaded male union installed with teflon tape from the MPV and reinstall it? If so, what should I use to connect; telfon tape or plumbers putty?
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    38,274
    Re: Replaced a MPV and one threaded union is leaking
    For those larger pipes, I think the Teflon pipe dope works better than the tape.
    Sep 2013
    Charleston, SC
    537
    Thank you. It is a very small leak, but I want no leaks. It is ok to remove the union and reseat with Teflon pipe dope?
    38,274
    Sure. Just don't over tighten it.
    I have one that leaks, but not enough for me to want to put in the effort to fix it. And the water loss is minimal.
    Jun 2015
    Wildomar, California
    423
    I've sometimes used both Teflon tape and Teflon paste to good effect many times.
    Sep 2013
    Charleston, SC
    537
    Thank you both. I am on the fence about loosening the joint now as it is such a small drip. I'll sit on this information for a few days!
