Page 1 of 13 123411 ... LastLast
Results 1 to 20 of 259
Thread: New Pool Build in Spring, TX
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Update 12.27.2015
    Final Review posted at post #240
    http://www.troublefreepool.com/threa...045#post955045
    Update 11.07.2015
    Initial fill complete. Waiting on startup.
    Update 08.10.2015
    Pre dig questions posted at #19.
    We're still a couple of weeks away (probably) from the dig. I want to prepare for the least amount of impact on our sprinkler system. I have 3 questions.
    1. Some of the heads will be covered by the deck and the equipment pad. We're considering digging these up prior to construction and either capping the to-be-covered heads or running all new lines so there are no joints under concrete. What did you do and what would you do different?
    2. The control valve system for the sprinkler system is on the side of house the excavator will use. So there is risk of damage there. The PB said he would try to have the operator miss the valve system. We have narrow access and can't take down the shared fence, so the PB is bringing in a mini excavator, but there is enough room where the valve system is to navigate around it. I'm not banking on the operator guy doing as he was asked. He'll make dozens of trips along that side of the house so I just know he'll run over them. What can I do to mitigate the damage? Maybe dig up the valve system and turn off the sprinkler system while construction is going on then re-install the valves?
    3. The side of the house where the excavator will run is sloped significantly. The PB said they would have to level it for the excavator. Probably by scraping dirt from the high side (near the house) and filling the low side (near the fence). Would we be better off bringing in extra dirt and building up the fence side? Might cause too much pressure on the wooden fence though.
    Thanks!
    Update 08.05.2015
    Signed contract last night! Had a tough choice between 2 excellent builders. Would have been satisfied with either one.
    Design
    In ground gunite pool with raised spa.
    33' x 17' free form
    12" wall along back
    440 pool / 500 total sq ft.
    17.8k gallons
    3.6' to 6'
    8 Waterway jets in spa
    Spa waterfall into pool
    Spa water bubbler
    6 stone scuppers on wall
    Oklahoma flagstone coping, wall and waterline
    Stamped concrete deck
    PebbleTec or PebbleSheen level 1
    (Images to come soon, I hope. I have hard copies but not digital)
    Equipment
    Jandy
    - 60 DE filter
    - 2.0 VS main pump
    - 2.0 Flo Pro for scuppers
    - 1.5 Stealth for PV3
    - Savi Melody 28w pool lights (3)
    - Savi Melody 14w for spa
    - PDA PS6
    - JXi 400K BTU natural gas heater
    Paramount
    - PV3 in floor cleaning system
    - MDX main drain in pool and in spa
    - SDX secondary
    Polaris
    - 1.5hp air blower
    Misc
    - Zodiac Nature2 Fusion Inground
    - Paramount ClearO3
    (I don't plan to run these. The builder includes them in his package. I hope I can catch the installers and just not install these.)
    (Removed original post as no longer relevant)
    Now the interminable wait for permits & lending.
    Build thread
    IG Gunite w/ spa, PebbleSheen Blue Surf, 18K gallons 500sqft
    Jandy: 60 DE filter, 2.0 VS (main pump), 2.0 Flo Pro (features)
    Paramount PV3 w/ 1.5 Stealth, PDA PS6, JXi 400K NG
    Flagstone coping & wall. Stamped Concrete from BrickForm. TF-100 w/Speed Stir.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,585
    Re: New Pool Build in Spring, TX
    Flip/flop it. Put The spa and mingle area on the right side by the table area.
    Will that be put it where the spa is looking into the bedroom? How do you feel about that?
    Kim
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Maybe I was a bit vague. I used the term "mingle area" to mean where the table and chairs are.
    We did flip the design but it pinches in the pool quite a bit on the left to leave enough room for table and chairs. From the left side of the house to the easement line is about 23 ft.
    I'm having a hard time envisioning how much deck we'll have and how much pool.
    Oh BTW the design you see is about 92 perimeter feet.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Welcome to TFP, and yay another Spring, TX pool.
    Depending on the amount of shade you get, you may want to factor into your design cooling your pool.
    I don't mean a heat pump, but sufficient water feature that you can run them early in the morning, when air is cool, to drop the pool temp.
    I can take mine down 2-4 deg on a good night.
    87 feels much better than 91 on hot days like we get July-August here.
    Deck jets, laminars and waterfalls all offer this. The SPA spillway does not get enough 'air' to be effective.
    Light directed away from house. The glare detracts from the pool at night for those on the patio or in the house.
    Depending on your budget, swim jets are an option for the lap swimmer. We use ours every day. I don't see mention of kids, but they are very imaginative of other uses for them.
    I see your concern about the mingling area. It's fine if the bedroom occupants are always the ones mingling.
    What, if any, are your restrictions from bumping out the deck to the fence on the left?
    This would let you recover some puppy space outside the bedroom.
    Do you have any plans for outdoor kitchen/gazeebo/grilling area?
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    Jul 2012
    Tallahassee, FL
    30,585
    awwwwwww I thought you were calling the mingle area the tanning ledge steps.
    Kim
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Quote Originally Posted by ozdiver View Post
    Not much shade until late evening. We plan to have a couple of sheer descent falls in the back wall.
    Not sure what you mean.
    We have a 5ft easement on the side fences so I think we're planning to use as much as we can.
    Nope. It's a challenge enough just to get a decently sized pool. The deck space shown is pretty much right at the minimum build size(I.e., minimum charge.)
    Thanks. I'm not super picky - just trying to make sure I haven't overlooked something important.
    Jun 2015
    Atlanta, GA
    640
    I would definitely want the spa to be closer to the Master Bedroom! So when you make a mad dash from the bedroom to the spa, you don't have far to travel. It would also be nice to hear the waterfall into the pool from your bedroom. Just my two cents!
    12K Gallon IG Lap Pool (c. 2001)
    6.6 ft x 48 ft/White Plaster/Concrete
    Pentair Superflo VS Pump 2.0 HP/Sand Filter
    Dolphin S300i Robot/SolarBreeze Robot
    TFT-100 Test Kit
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Regarding the lights.
    Setting them in the wall closest to the house facing away lets them reflect off the far wall and look good.
    If they are in the wall opposite the house facing back toward it, the glare is not nice and detracts from the view.
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    OK. Gotcha. That pic doesn't show the lights but in the night time image he has the lights facing away from the house. So, I think we're good there. Thanks! I would not have thought about that since they are under water.
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Update:
    We have a bid from our 2nd builder (not the one who provided the rendering in the OP). This builder quotes:
    500 Sq Ft (approx 17K gallons)
    Stamped concrete decking of about 400 sq ft
    Jandy 60 DEV or 580 CL filter
    Jandy 2.0 hp Stealth filtration pump
    Jandy 2.0 hp FloPro water feature pump
    Jandy JXi heater
    Jandy PDA PS6 pool computer
    Polaris 280 w/ 3/4 hp booster pump
    Brass skimmer lids and 6" brass drains in deck where needed
    Jandy Savi Melody colored LED lights (6 total)
    Pebbletec or Pebblesheen level 1 color
    Spa has 8 jets and a water spout
    Chlorinator: Nature2 fusion and Paramount Clear03
    Full startup plus 2 months of pool service
    Oklahoma flagstone coping and water feature wall
    Water features: 6 scuppers
    Builder 1 hasn't provided detailed specs but here is my understanding
    About the same size pool and spa
    Pentair (Sta Rite) VS pump
    (No separate water feature pump)
    Water feature: 2 x sheer descents
    Paramount PCC2000
    3 white LED lights
    Flagstone coping
    Kool deck about 400 sq ft
    I believe 6 jets in the spa, but could be 8.
    No remote control
    Heater (not sure what kind or how many BTU)
    PB1 is about $2,000 less than PB2.
    Here are the significant differences as I see them:
    PB1
    - includes PCC2000.
    - uses Kool deck.
    - does not include remote control.
    - uses VS pump.
    - does not use 2nd water feature pump
    PB2
    - uses stamped concrete with a sand treatment to reduce slickness.
    - uses Savi colored LED lights
    - uses PDA remote control.
    - uses separate water feature pump
    - uses single speed pump
    PB2 says that the single speed pump will run 6 - 8 hours a day depending on how much daylight you get and that a VS pump won't save us much money, especially when you consider replacement or repair costs. I'm dubious of this claim, but I have read that VS pumps are much harder to repair.
    PB2 insists on the Nature2 and ClearO3. It's his package deal. I suppose I could just turn them off once installed. I don't know if he'll go for it, but I think I'll propose to trade the Nature2 and Clear03 for a VS pump.
    I haven't done the math completely, but once differences are accounted for, I believe the bids to be close enough to not matter. I'm down to - do I go for the PCC2000 (PB1) or the other extra features (stamped concrete, multi colored LED lights, remote control, separate water feature pump) from PB2.
    Related question: How often do those of you with a Polaris or Dolphin cleaner have to handle these things? Is this an everyday activity or just 2 or 3 times a week?
    We go to talk to PB1 to get solid bid Monday after work.
    Thoughts welcome. Thanks!
    Jun 2015
    Atlanta, GA
    640
    We run our Dolphin robot at least once a day.
    TFT-100 Test Kit
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    Once a week at most for us, usually less.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    OP updated. Contract signed last night! Now off to the bank!
    Build thread
    Jul 2012
    Tallahassee, FL
    30,585
    How exciting! Better get some adult beverages to calm the nerves! LOL
    Kim
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Maybe AFTER work. Haha
    Build thread
    Sunbaby's Avatar
    Feb 2015
    Conroe, TX
    1,309
    Pop a cork! Time to celebrate!
    ~Wendy
    33'X17' Sports Pool (3'6"-5'-4'6") 7' flush Spa, Blue Granite PT, Waterfalls, Weeping Wall, Baja Ledge and Doggie Beach Entry! Pentair Clean and Clear 420, IntelliFlo XF Pump, SuperFlo 1.5 HP Feature Pump, MasterTemp Heater, Pal-Treo LEDs, Dolphin M4, Liquid Chlorine & TF-100 - My Build Thread
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Absolutely! A short rest and then we get to experience what a few of you already did this year. Thanks!
    Build thread
    Jul 2012
    Tallahassee, FL
    30,585
    Quote Originally Posted by bdrums View Post
    BUT boss Kim said I HAD to have a drink NOW! LOL
    Kim
    bdrums's Avatar
    Jul 2015
    The Woodlands, TX
    251
    Thanks!
    Build thread
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,585
    I would not have any part of the sprinkler system under the concrete for just in case needs in the future. Why even take the chance you will need to bust it up?
    -Valve system-build a temporary "building" around it and paint it a BRIGHT color. Just some pieces of plywood to make cover it and act as a buffer. With the bright color he will be more apt to see it.
    -no help with the grading. Maybe a picture will help.
    Kim
