Thread: Raising CH
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Raising CH
    My CH is a little low (225) for a plaster pool so I am looking to raise it to 260.
    Is it ok to swim immediately after adding calcium chloride? Or should I wait until tonight after last swimmer is out?
    40k gal freeform, IG pebblesheen, 9'x'6' raised spa, 2-1/2 hp Whisperflo, 520 sq/ft cartridge, Legend w/ booster, Intellibrite 5g in pool @ spa, Rainbow 320 Chlorinator(retired),
    Mastertemp 400k BTU, 3x3 hp Whisperflo Swimjets, 2x2 hp Whisperflow for 15ton moss rock waterfall, Intelitouch Controller, 850 sq/ft Travertine deck, Gas/Wood firepit,
    Autofill, TF-100 test kit w/ SpeedStir
    38,284
    Re: Raising CH
    In TX, I would not add any CH ... it is going to rise fast enough just due to evaporation.
    Mine rises about 150ppm yearly.
    ozdiver's Avatar
    Oct 2014
    Spring, TX
    570
    Re: Raising CH
    So your's rises due to replacement of evaporated water with hard water?
    In Houston we get a lot of rainfall, so often mine is topped up that way.
    This time of year the autofill adds a little.
    Obviously my pool is young (3 months) but mine has been locked at 225 since I filled it.
    38,284
    Re: Raising CH
    Yes. My tap water is about 130ppm. I did a complete refill 2.5 years ago and my CH is now 450ppm.
    While the CH was low, I just kept the pH a little higher to keep the CSI in range. Now I have to try to keep the pH on the lower side. Likely will have to replace the water again in a year or so as the CH gets higher than I want.
