Thread: Liquidiator WS - if it is calcium could the device be useful to lower calcium levels?
    May 2015
    Southern California
    8
    I was thinking about getting a Liquidator, but I've not digested all the pros and cons from the discussions on this forum. However, living in an area where the fill water is extremely hard and has a great deal of calcium, I was wondering if the WS that precipitates out in the bottom of the Liquidator contains calcium might it not be helpful for those wanting to reduce the levels of calcium in the pool water.
    My calcium level is approx 630 in a 25,000 gallon IG plaster pool.
    If the Liquidator does indeed cause calcium in the pool to precipitate out into the bottom of the Liquidator tank then it might be a practical way to remove calcium from the pool.
    Would there be any downside or a better alternative to reduce calcium?
    25,000 gallons. IG plaster, using liquid chlorine and muriatic acid
    DE filter, 48sq feet filter area, Pentair VS pump, TF100 test kit
    Aug 2014
    Shallotte, NC
    693
    Re: Liquidiator WS - if it is calcium could the device be useful to lower calcium lev
    According to the patent, what precipitates out is NaCl, not calcium. I have sediment in my Liquidator, but I doubt it is calcium.... I suspect it is some kind of salt from the chlorine and, I guess, salt....
    Ellington, CT
    262
    The white stuff that precipitates out and fall to the bottom of the tank (White Stuff on bottom or WSB) is mostly sodium chloride a.k.a salt or NaCl. As ewkearnd points out, Hasa makes a specific claim for this in their patent. However they do make a statement in the Liquidators Instruction and Use Manual (LI&UM) that it also precipitates calcium
    Quote Originally Posted by Liquidator Instruction and Use Manual
    Softens and cleans the pool water by precipitating calcium scale and contaminants
    Its when the white stuff starts getting stuck on stuff (white stuff stuck on stuff, or W3S), that problems arise. The LI&UM address this in the “Periodic Maintenance” section of the manual:
    In areas with hard water, calcium scale may periodically build up on the float assemblies, particularly the “OUT” float. This could cause the float valves to not close off properly. It is important that you keep the pool pH in the lower end of the normal range (i.e., towards 7.2) as well as keeping the alkalinity below 100 ppm to help prevent scaling in the unit. Should this buildup occur, remove the floats from the tank and clean them in a diluted solution of
    muriatic acid.
    So I guess the down side on counting on the Liquidator to reduce high level of calciums is that you have a potential of calcium scaling.
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    May 2015
    Southern California
    8
    Thanks, I'll factor your thoughtful guidance into my decision on the Liquidator. Are SWG's worth considering -- are they the greatest or or their downsides with them as well>
    Aug 2014
    Shallotte, NC
    693
    IMHO, and this might qualify as another thread, but the LI&UM is joking if they think you can keep TA anywhere near 100 and the pH at 7.2..... I'm down to TA=60 to hold a steady(ish) pH=7.4....
    Ellington, CT
    262
    In the Start up section, LI&UM states the following
    Quote Originally Posted by Liquidator Instructions and Use Manual
    BEFORE OPERATING THE LIQUIDATOR ® THE POOL WATER MUST BE BALANCED:
    pH 7.2 to 7.6
    Alkalinity 80 to 100 ppm
    Stabilizer (also referred to as conditioner or cyanuric acid) 60 to 80 ppm maximum
    For reference I do not get any significant W3S and my TA is 50 to 60 ppm with a ph of 7.6. I do enjoy low CH however at 100 to 140 ppm
