Results 1 to 7 of 7
Thread: new opening-no cya- have tabs and granular
    Jun 2015
    Quarryville/PA
    58
    Just opened pool. Need to begin balancing. At this point no stabilizer present. I have in my possession a huge bucket of 3" tablets and another of granular (dichlor). Is it possible to use these to start? Wondering if it will raise cya enough while maintaining fc. I hate to waste them.
    27' round ~ preowned ~ beginning install ~ replacing smaller pool
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Re: new opening-no cya- have tabs and granular
    How do you know you have no cya? Can you post your test results?
    Inground 13,200 gal Vinyl, Pentair 3/4 hp pump, Pentair Sand Dollar filter, Polaris 280
    Pool School, Pool Math, CYA to FC ratio chart, Testing Kits
    38,301
    You can use the effects of adding chemicals section at the bottom of PoolMath to calculate how much CYA the tablets and Dichlor will add. You will lose a lot of FC until the CYA gets up to around 30ppm.
    I agree with the above post though. How do you know the CYA is 0? What test kit are you using?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    You can use those products, but I wouldn't recommend it. Why? 1) They are acidic. You might find out the cost of Borax and Bakling Soda or Soda Ash to counteract the pH drop and TA reduction negates any savings. On the other hand, if you have really high TA and the pH is also high and rising, it could work. 2) They take a long time to dissolve. Let's say you target 50 CYA. Every 10 FC you add via trichlor pucks will also add 6.4 CYA. To get to 50 CYA (82 FC), you'll need to add 204 ounces of pucks - that's almost 13 lbs.... 26 pucks... which will take weeks to dissolve. Assuming a loss of 3 FC per day, that's at least 27 days. Summer will be over before that!
    Perhaps adding CYA to get to 30 initially, and then chlorinate with the powders until you hit your target CYA. As long as the bucket stays sealed, your dry chlorine leftovers will last for years.
    Jun 2015
    Quarryville/PA
    58
    I tested earlier today with
    Leslie's DPD test kit
    Ph 7.2
    alk 120
    fc 0
    stabilizer test done with
    aqua chem kit 0
    Have to run quick errand . will recheck water and for resposes when i get back.
    Jun 2015
    Quarryville/PA
    58
    I guess one of my questions would be, how long does it take for the cya levels to increase beyond desired level. I'm thinking' since it is basically August, perhaps use the chemicals I have been provided following pool store's instructions and then just start fresh with this method in the spring. Any thoughts?
    38,301
    You can use them fine given the late start and short season. Ideally you should get a better test kit.
