Thread: Test Kits Reading Differently
    Jul 2015
    North Richland Hills, TX
    2
    Question Test Kits Reading Differently
    I haven't splurged yet and bought a good kit, that is coming. I refilled our pool last week. I bought a cheap test strip kit that would read CYA and FC. To date, the test strips have read nothing more than a 2/4 no mater how much sanitizer I have added (8% Chlorox). I have also added the stabilizer at start up and I understand that it takes about a week to fully disolve, so I have been patient. We have temps of 100 daily and I know it is burning off quickly. I added 6 Cups of Chlorine yesterday late afternoon, even though poolmath told me that about 2 cups would get me up around a 4 or more. I expected to get a decent reading this morning. FC 0. My pH is 7.5, CYA 30-50, TA 80. Just to see, I decided to test using the reagents and my total chlorine is reading at least 5. The water hasn't been in the pool long enough for a build up of total chlorine and no FC. Are these test strips worthless? Is the reagent kit just not enough info? Am I just going to be flying blind until I order the good kit? Thanks!
    AG, Intex 12'x36', 2500 gal, vinyl, A type cartridge, Re-filled with city water 7/23/2015, HTH reagent kit for chlorine and pH, HTH mult-ipurpose 6-way test strips
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,591
    Re: Test Kits Reading Differently
    Yes----test strips are worthless. it oesn't take cya that long to dissolve-just up to a week to accurately measure on a good test kit. Add it in and treat the pool like it's there with FC levels. Welcome.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    Toss em! Dip your finger or toe in the pool, hold it up to the wind and say the first number that pops into your head and you'll probably be closer.
    We had someone with brand new plaster recently who was about to add a whole bunch of borax to raise his PH based on test strips. We held off, got a good test kit and the PH was almost perfect. That would have been very bad for his pool if he had done that.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Test strips can bleach out of the chlorine level is high which will give you false readings. So can the DPD drop test. Only the FAS-DPD tester can give you accurate readings at high FC levels. The OTO test won't bleach out, but the shades aren't distinct enough to use it with any accuracy.
    And welcome
    Jul 2015
    2
    I figured as much, thanks!!
    Jun 2014
    15,078
    If nothing else today, Pooldv gave me a gut-busting good laugh on that one about test strips. Wow, I need that.
    I love my TF-100 w/ speed stir! TFTestkits.net
