Results 1 to 7 of 7
Thread: Water looks awesome, do I need to do anything?
    Jun 2015
    Bedford hills ny
    46
    My water looks awesome but my TA is still too high. I read that we aren't supposed to do anything if TA is high but it isn't causing other problems. Now my PH has gone too high as well...
    44k gallon plaster swg pool
    FC 4.6
    CC 0.0
    Ph 8.1
    TA 95
    Hardness 320
    CYA 60
    Should I lower the Ph to 7 then aerate?
    20' x 50' AG gunite pool (no idea on gallons) built a long time ago. DE Filter w/Hayward Pump. Well water.
    Re: Water looks awesome, do I need to do anything?
    Just lower the ph to 7.2 and monitor. No need to aerate.
    Support the site
    Jun 2015
    Bedford hills ny
    46
    Thank you
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,050
    I concur. Add acid to lower pH, give it time to mix so nobody swims through an acid bath, and
    Jun 2015
    Bedford hills ny
    46
    Awesome thank you
    Jun 2015
    Bedford hills ny
    46
    Could the acid have raised my FC level?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    No, it won't raise FC.
