Thread: Minor Green Spots
    Jul 2015
    San Diego, CA
    3
    Minor Green Spots
    Over the last two years, I've had minor hard green spots in the spa which I simply scrubbed and then shocked. They typically return several months later. Now I'm starting to see some spots in the pool and also in the pool equipment, such as the hose in the pool (although appears to be softer). Overall the pool is always clear. I haven't had an algae bloom in years.
    This is a salt water pool. I use Pool Perfect with PhosFree about every two weeks.
    See pictures.
    Suggestions how to get rid of this hard algae stuck to the sides and now in the equipment?
    -- Mark
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Minor Green Spots
    Welcome to TFP!
    Skip the pool perfect and phosphree. It isn't helping and wastes money.
    Buy a good test kit, Pool School - Test Kits Compared and test your own water. I use the TF100 from TFTestkits.net
    With algae in the pool you will need to Pool School - SLAM - Shock Level And Maintain your pool to kill the algae once and for all.
    After the SLAM, maintain your pool TFPC style and you will save time, money and have better water.
    Some good reading here,
    Pool School - Water Balance for SWGs
    Jul 2015
    San Diego, CA
    3
    Thanks for the pointers, however, I've been thrilled with the Pool Perfect and Phosphree. It is relatively inexpensive and since using it I've never had any cloudy water or algae blooms. I usually keep my PH very consistent and phosphates register very low, however, the SWG did go off 2-3 days. The water is very clear. Granted I showing a few algae spits on the walls and hence the post. The green I'm showing represents far less that 1% of the pool surface area - it is in about 5 spots across the entire 20'x40' pool. I see the SLAM method being recommended for all conditions and most of those appear to be regular algae booms. I was wondering if there was something specific needed for this type of occurrence - is this green algae or black (looks green!)? maybe insufficient pump run time? Not scrubbing well to remove the few spots?
    -- Mark
    38,284
    Any sign of algae warrants the full SLAM process. It started because you let the FC drop too low.
    domct203's Avatar
    Jun 2015
    CT
    3,583
    Quote Originally Posted by MarkSD100 View Post
    ......... Thanks for the pointers, however, I've been thrilled with the Pool Perfect and Phosphree. It is relatively inexpensive and since using it I've never had any cloudy water or algae blooms..........
    You are experiencing an algae bloom right now...... That hose didn't get like that overnight.
    There is no acceptable level for algae, zero, nada. It's not OK to be "showing a few algae spits on the walls".
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
