Results 1 to 15 of 15
Thread: Pool Noob and First Time Slam
    Jul 2015
    Warsaw/IN
    6
    We have been battling a green pool all summer long. We basically gave it the finger a few weeks ago and have done nothing to it since. I found this forum over the week and have decided to get aggressive. I bought a Taylor test kit on Friday and started our slam Friday night. We have a 27 foot above ground pool with a sand filter. our pool is in full sun for most of the day. Mostly I just want to make sure I'm not missing anything.
    PH 7.4
    TA 80
    FC 15
    CC <.5
    CYA <30
    According to the pool math calculator I should be targeting a FC level of 10 (I estimated CYA to be around 20?) I have not left the FC level drop below 10 since Friday night. I have been running the filter constantly as well as our cleaner robot. I have not scrub it yet because I can't see what I'm doing. I was thinking I would get in and scrub once the water cleared up just a little. I cannot even see the bottom of our pool. We should probably just start calling it a pond at this point. I know this can be a long process and I just want to make sure that I have thought of everything and I'm following the directions for slam thoroughly. Any advice or directions would be greatly appreciated.
    Thanks in advance.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Re: Pool Noob and First Time Slam
    Test every hour for FC and CC, until your pool maintain your level, then you can test less often, good luck, just remember to backwash when your filter pressure raise 20-25% and scrub every day , the more the better
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    Should be pretty easy to brush that AGP without getting in. If it was mine, and water replacement/disposal was not an issue, I'd pump it halfway down and then start again. Too hot this time of year not to be enjoying it as soon as you can and summer is getting shorter!
    Jul 2015
    Warsaw/IN
    6
    Thanks for the responses. We have well water and I think by the time we drained it halfway and then refilled it it will probably take about as long as the slam does anyhow.
    I checked my FC levels after an hour and they appear to be dropping by 2 ppm per hour. My CC is still not registering. By my calculations I need to add a gallon of chlorine every 2.5 hours. I've been reading that you all recommend bleach, just wondering why. The stuff I'm using is 10% sodium hypochlorite which I believe is basically bleach?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Either is fine, it is the same thing just different percentages, whatever is easier to get and better price. Yes, if you test and add every hour or two that will make your slam go faster. So will getting a net and scooping out all the leaves and stuff and brushing.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Welcome!
    Brush blindly if you have to. Algae forms a slimy biofilm that protects it from bleach. Brushing scrapes it off so the bleach can kill it. Don't be surprised if your FC drops much more than it has been after you brush.
    Jul 2015
    Warsaw/IN
    6
    I brushed the sides about 30 minutes before I tested the FC so I'll test again in an hour. There really isn't any solid matter in the pool to scoop out. How often should I brush down the sides and should I be brushing the bottom as well?
    Richard320's Avatar
    Jan 2010
    18,966
    Quote Originally Posted by Westerin View Post
    Brush it all at least once a day. If you have anything in the pool like steps or ladders or lights, they should be scrubbed out, too. Also, based on someone else's recent experience, I'd suggest checking the skimmer weir and throat, if you have one. Which brings up an interesting point.... we have no idea how big your pool is or if it's above-ground or in ground or what, and that can affect the advice we give. Please fill out the signature line.
    Jul 2015
    Warsaw/IN
    6
    Sorry, I saved the pool size in my first post but did not put it in a signature. I really don't know much about our equipment because it was here when we bought the house, but I posted what I could tell. If the skimmer is the little box that hangs off of the side of the pool, but I have one of those as well. Thanks for the help and let me know if you need any additional information.
    27 foot AGP w/ vinyl liner. Waterway 19 in Sand filter and pump
    Apr 2010
    East Texas
    9,552
    We have a 27 foot above ground pool with a sand filter.---------Yeah Richard, we do. Sig line still requested though!
    Jul 2015
    Warsaw/IN
    6
    Is it possible to have the FC too high? I work during the day and was going to put in enough to keep it above 10 until I get home in the evening. Also thought I'd check and make sure that our filter is a sufficient size for our pool. Thanks! I know next to nothing about pools.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Are you slamming today? Please post your FC and CC that you have tested today and the time the test was done, so we can see how much ppm are you loosing
    Jul 2015
    Warsaw/IN
    6
    I have been slamming today. I've been testing at hour intervals throughout the day (not hourly) and appear to be losing about 2 ppm per hour. I'm thinking I would need to have it at about 18 PPM when I leave in the morning and can add a gallon or 2 over lunch.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Is OK to be a little above the the slam level but I am not sure about 18 I will let others answer that
    DFW, TX
    24,450
    18 is mustard level chlorine for 30 cya. So, yes you can raise it to 18 before work to help through the day.
