Thread: New spider gasket problem
    Jul 2015
    Muldrow,ok
    1
    I observed water flowing out of the backwash port on filter setting and determined I needed to replace spider gasket.
    I ordered gasket kit and proceeded to replace gaskets. After thoroughly cleaning channels and lightly gluing (rtv) I proceeded to install
    Lever halve of valve. When set it on top there is a gap about a 1/8 inch wide. When I bolt it down it compresses the spring like there is an obstruction
    or the gasket is too thick. When I bolt it down the handle goes limp.
    The gasket seems to be the correct fit.
    I installed it flat side down.
    I also installed new valve shaft and flange oring
    Can anyone help?
    15k gallon inground pool
    1.5 inch lines with sand filter
    3/4 horse wisperflo pump
    Casey's Avatar
    SW PA
    10,453
    Re: New spider gasket problem
    Welcome to TFP.
    Lets see if anyone can help you with this!
