Thread: How to protect the pool from yard work dust?
    gamerasian's Avatar
    May 2015
    edison/nj
    85
    So we have decided to keep the pool!! But our yard work is not finished yet. We still need to put the bricks in the retaining wall and fill it up. The pool guy is coming to fix it and we were hoping to save the pool from getting all the dust from the yard work. Any ideas? Or any easy steps to clean it up if the pool dirties up due our yard work?
    thanks
    24k IG vinyl , new (not any more)pool, new ( not any more) water Hayward super pump and sand filter.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,421
    Re: How to protect the pool from yard work dust?
    Filter! What kind of filter do you have?
    If you have a 2 speed pump turn it on high. If you have a bottom drain shut it off and let the skimmer do all of the pulling so that any dirt that settles on the surface will go into the skimmer and get filtered out.
    Kim
