Results 1 to 8 of 8
Thread: What my new pool heater cost me
    daleyfolk's Avatar
    Jul 2014
    Boise,Idaho
    51
    SEE MY HEATING COSTS UPDATE further down the thread.
    I thought it would be interesting for those considering getting a heater for their pool.
    I decided on natural gas heater. Pool store got me a 266k Rheem for my 17.5k pool.
    $1250 Gas company needed to run 128 ft of gas line from side of my house back to the pool shed area and hang a new meter. (we couldn't run off the house gas for some reason)
    $1995 Cost of heater
    $135 Parts
    $360 4 hours of labor. (The pool guys helped me pull out two bushes, they set the heater on some pavers and levelled it) 4 hours? really? hmmmm
    $342 Electrician
    $500 HVAC guy to install approx. 12 feet of pipe (through two walls) from new gas meter to the heater.
    TOTAL = $4582.
    Cost to run (I keep it about 85F):
    First partial month: (May)$176
    June: $115
    July: $78
    EDIT: UPDATE for 2016 down the thread.
    Sounds like a lot.... but I LOVE MY POOL!!!
    17.5 K gallons (16x32) vinyl inground pool with 1 hp pump and an old Triton sand filter. >20 years old. New 2015 Rheem gas heater. TF-100 Test kit. Little red robot and a Pool Blaster Max.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,201
    Re: What my new pool heater cost me
    Here's to warm water! It makes all the difference. Thanks for the info!
    Jul 2012
    Whidbey Island, WA
    392
    Quote Originally Posted by daleyfolk View Post
    June: $115
    July: $78
    Interesting, thank you.
    What was the ambient temperature in June and July in Boise?
    Why? To compare to here on Puget Sound.
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    daleyfolk's Avatar
    Jul 2014
    Boise,Idaho
    51
    In June and July it's been quite hot. High 80's, 90's, some 100's with a record 110 on June 28. We are a high-desert climate and it usually cools down at night by 15 degrees or so.
    I'm pretty religious about covering the pool each night with solar blanket. (except when it was 110F, I left it off for about 3 nights)
    Jul 2012
    Whidbey Island, WA
    392
    thank you
    with Puget Sound temps I will never achieve your low heating costs
    oh well, what are grandchild giggles worth
    daleyfolk's Avatar
    Jul 2014
    Boise,Idaho
    51
    Original poster here...Updating my heating costs. Hoping this helps someone who is considering a gas pool heater.
    2015:
    May $176 186 therms
    June $115 121 therms
    July $78 81 therms
    Aug $118 125 therms
    Sept $205 217 therms
    Oct $138 149 therms (shut it down first week in Oct.)
    2016: (I kept the pool warmer this year...about 88F)
    May $215 237 therms
    June $175 192 therms
    July $118 129 therms
    Aug $116 126 therms
    Sept $270 297 therms
    (shut it down Sept 21)
    Gas is billed at approximately $.95/therm.
    LOVE LOVE LOVE my warm water!
    DFW, TX
    24,201
    Thanks for the update. Are you still using a solar cover every (most) nights?
    daleyfolk's Avatar
    Jul 2014
    Boise,Idaho
    51
    Yes. I cover it every night.
    I'm still covering it (to keep the leaves out) even though I'm letting the water temp drop before closing it.
