Thread: Conflicting information when replacing spider gasket (Praher SM20-2)
    Jul 2015
    Ausitn, TX
    2
    I'm in the process of replacing the spider gasket on a Praher SM20-2.
    Tried searching the site, and internet, but I'm getting conflicting information on the following areas:
    1) Does the ribbed side of the gasket go up, or down?
    2) Do I use the Permatex Blue RTV Silicone gasket maker, or Silicone Adhesive to secure it?
    3) Do I wait 1 hour after installation to start the pump again, or 24 hrs?
    Thank you much in advanced for any assistance!
    ~2000 cuft / 15000 gal, plaster, in-ground, built 1991
    Jandy SHPM2.0-2, DE filter (Jandy Dev60)
    Polaris Vac-Sweep 380 w/PB4-60
    Small waterfall feature
    Casey's Avatar
    SW PA
    10,423
    Re: Conflicting information when replacing spider gasket (Praher SM20-2)
    Welcome to TFP.
    I'm gonna give you a bump because I do not know and maybe someone can help.
