Results 1 to 16 of 16
Thread: Green particles on bottom of pool, won't go away
    Hey guys,
    I've had this pool for a couple of years now, and about halfway through the summer, it ends up looking like the attached images. I've tried algaecide, and my wife has vacuumed it a couple times within a week, and it still comes back. Any ideas what it is or how to get rid of it?
    Edit:
    Levels:
    fc 3
    ta 100
    cya 30
    ph 7
    Other data unavailable
    Intex Ultra Frame 18'x48" Round Pool (7,500 Gallons, Above Ground)
    Intex 56671EG 2,650 GPH Sand Filter Pump
    Intex Pool Maintenance Kit- Deluxe Edition
    Pool filled from drilled well
    30,395
    Re: Green particles on bottom of pool, won't go away
    Welcome to the forum.
    That's dead algae (mixed with live) and it is because your pool is under chlorinated. You are at the right place if you would like to get rid of that forever.....especially if you want to understand what caused it in the first place.
    In short, more chlorine is needed in your pool. We need to know your current test results to discover just how much more you need, Can you post them?
    I would suggest you read "The ABC's of Pool Water Chemistry" up in Pool School. It is a great start to understanding.
    I edited my original post to include my test results.
    38,235
    What test kit are you using?
    To eliminate the algae, you need to follow the ShockLevelAndMAINTAIN Process. After passing the 3 criteria to stop, You will need to maintain adequate FC for your CYA level according to the FC/CYA Chart to prevent the algae from returning (no need for algaecides or potions )
    Just the bottle of test strips from the pool store. I think the brand is Aquacheck.
    38,235
    Test strips are not sufficient for maintaining a pool. They have repeatedly proven to be inaccurate and not reliable.
    To take control you are going to need to invest in one of the Recommended Test Kits and then follow the suggestions I previously made.
    Hmm. I live in upstate NY. I only have the pool up for 3 months out of the year. The pool was only $300. How long will the kit last?
    38,235
    Should last a few seasons if stored properly.
    With the kit and learning our methods you can guarantee a sparkling pool all summer and not lose precious days/weeks to green water.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Quote Originally Posted by jephph View Post
    Where??
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Quote Originally Posted by ship of fools View Post
    Where??
    Not Albany
    Between Syracuse and Watertown. We actually hold records for snowfall in the US.
    Will balancing the levels make the algae go away, or do I still have to vacuum it out? And since we've already tried vacuuming several times, do I have to vacuum to waste?
    domct203's Avatar
    Jun 2015
    CT
    3,574
    The SLAM will kill the algae, but removing as much as you can by vacuuming to waste will help the SLAM go quicker.
    Please have a read through Pool School, it will really help you understand how to properly care for your pool.
    I have basically the same pool setup as yours, and the water sparkles! Since following Trouble Free Pool Care it has never looked better.
    You will definitely need one of the recommended test kits. I know it seems like a big cost up front, but it will save you money over the next couple of seasons.
    How are you currently chlorinating the pool?
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    You don't have too, but it would be helpful to get some of that Algae out before you SLAM, because it will make it easier for your Chlorine to function when you perform the procedure.
    But yes, balancing and keeping it balanced will absolute.y make this go away, and stay away. Now and forever.
    Essential Links:
    Quote Originally Posted by domct203 View Post
    Dom
    Bleach from the dollar store. How often do you test with the kit? How long does it take to do all the tests?
    Jun 2015
    Raleigh
    357
    When you are SLAMing you test as often as possible...every couple of hours because you want to keep adding bleach to maintain your shock level. Once the initial algae kill occurs and your FC starts holding you can reduce the frequency. The test itself takes a couple of minutes. However long it takes you to get a water sample from your pool and add some drops.
    After your water is clear and you pass OCLT you can just test once a day.
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Nov 2011
    Albany, NY
    495
    Not Albany
    I went to college (Canton ATC) with a guy from Adams and another from Henderson Harbor. The Henderson guy moved to Parish. So i am familiar with your pain!
    Haywood Sand Filter
    Vinyl Liner
