Thread: Replaced thermister, MInimax still reading 110 F
    Jul 2015
    Los Angeles, ca
    3
    My 10 year old minimax heater was reading 110F where pool sensor and thermometer floating in pool agreed it was 84. FIgured 10 year old thermister was failing and replaced it with correct part. Same reading after replacement. Guessing its the board, but anyone has input would be greatly appreciated.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Replaced thermister, MInimax still reading 110 F
    Is it reading 110 right when you turn it on?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jul 2015
    Los Angeles, ca
    3
    Quote Originally Posted by ps0303 View Post
    Yes. usually tracks pool temperature, may read 108 if pool is 82 , 110 if 84. Consistent offset. Poll controller reads correct temperature as measured in pool. Cant think what it be other than board now that brand new thermister doingsame thing as old one.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Yes if you already replaced the thermistor and it's still reading incorrectly, then it could be the board. This is a minimax NT correct?
    Paul
    Jul 2015
    Los Angeles, ca
    3
    yes . minmax nt Low NOx Series 6800 control board
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    So then I guess its the board. I've seen where the display on the board is messed up and it shows weird stuff.
    Paul
