Results 1 to 15 of 15
Thread: New pump time
    Jul 2015
    Albany ny
    9
    New pump time
    My pool pump has gotten very noisy and it's time for a replacement (this one is about 10 years old from what I can tell).
    I have a rectangular pool 20x40 so about 33k gallons with 1.5 inch piping. The current motor is a pinnacle 1 hp single speed. The previous homeowner was running the pump 24/7 for the 5 month season.
    I'd like to find out your opinions on switching to a pentair whisperflo 2 speed 1hp. From what I've read, I should be able to run this on low during the day and then high at night. Any other recommendations? Do these have a timer for switching?
    I honestly don't have a problem with a single speed but my goal is quieter and under $600 - I have no issues continuing to run it 24/7.
    38,254
    Re: New pump time
    Welcome to TFP!!!
    If the pump itself is still fine, it would be cheaper and easier to just install a 2-speed motor on your existing pump (no plumbing required). Just add an external switch to manually select speed and generally leave it on low all the time, except when you are vacuuming or backwashing.
    There is also no reason to be running a pump more than about 4-6 hours per day typically. See this: Determine Pump Run Time
    If you do not have a timer, then I would suggesting adding one for on/off control. Optionally, you can add another timer to automatically change speeds.
    Please add your pool details to your signature as described HERE as it will help us help you.
    Jul 2015
    Albany ny
    9
    Re: New pump time
    That's a great idea! Any suggestions for 2-speed motors?
    38,254
    Re: New pump time
    Any that match the SFHP rating (service factor * HP) of your existing motor and have the same motor frame.
    Jul 2015
    Albany ny
    9
    33k gallons IG vinyl pool (20x40) with a Hayward 18" sand filter.
    38,254
    Re: New pump time
    What is the HP and SF listed on your current motor? The new one must be at least that size or you would need to add a smaller impeller.
    Also note you need to replace the shaft seal when you change the motor.
    Jul 2015
    Albany ny
    9
    Re: New pump time
    I saw that about the shaft seal - do o just buy a generic one? The one I currently have is a 1hp and 1.25 sf.
    This seal mentions pinnacle pumps - Pentair Shaft Seal OEM 5/8 - 354545S - INYOPools.com
    Jul 2015
    Albany ny
    9
    Re: New pump time
    Thanks so much for your help. The two speed 1 hp with that seal is under $400. Sounds good to me.
    38,254
    Re: New pump time
    OK, so the smaller 1.25 HP motor is all you need (the bigger motor would work with your existing impeller, but just costs more although not much) and seems like that shaft seal should work.
    There are also go-kits that include all the seals in the pump plus the shaft seal.
    Jul 2015
    Albany ny
    9
    Re: New pump time
    I ordered the larger one since the hp number was the same and it was only a $4 difference and I also got a full tune up kit which includes the seal. This will definitely be a lot quieter!
    Jul 2015
    Albany ny
    9
    Re: New pump time
    Got the new motor installed and I'm getting a fault 7 error code which it says over current fault - disconnecting power and rotate the shaft. So did I over tighten the propeller?? Not sure what to do.
    Mar 2015
    Sugar Land , TX
    424
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Jul 2015
    Albany ny
    9
    Re: New pump time
    Good so I did everything correct for wiring BUT I'm trying to hunt down if I'm now running or attempting to run 115v to 230v motor
    38,254
    Re: New pump time
    There is a plate on the motor that says how to wire it. They are usually 230v motors.
    Jul 2015
    Albany ny
    9
    Re: New pump time
    Quote Originally Posted by GiantsnationNY View Post
    So turns out A.O. Smith (Century motors) is hiding a bit of information here. Nothing in the manual (or common sense) says that when this error occurs it means a defective unit - essential DOA. I'm really disappointed that they don't mention this.
    Luckily, I've called Century and they're sending me a new motor.
