Results 1 to 7 of 7
Thread: Trouble balancing pool after ascorbic acid treatment
    Folks -- ascorbic acid treatment went great. Iron stains lifted like magic.
    So I used Poly60 to hold off algae and that went okay. So I started adding Chlorine back and the pool turned iron yellow/brown. So I added a modest amount of ascorbic acid back to the pool and bang, it went away.
    I've been struggling to raise chlorine levels without getting the water to start turning brown again. And I've been fighting algae as a result.
    What's the trick? What am I doing wrong in terms of bringing free chlorine levels back up without the pool turning funky colors?
    Thanks!
    15,000 gal SWG pool, cartridge filter, all pentair equipment, variable speed pump, 400K BTU heater and spa, pebbletec finished
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,377
    Re: Trouble balancing pool after ascorbic acid treatment
    You need to add sequestrant before you start bringing the FC up. Or if you have a source of iron free water you could drain and refill. If that is not an option get a good sequestrant based on HEDP, phosphonic acid, or phosphonic acid derivatives and follow the directions for adding it to the pool. You will need to add sequestrant regularly to prevent the stains from coming back.
    Love TFP? Become a
    TFP Supporter!
    Quote Originally Posted by zea3 View Post
    I've tried to avoid phosphate containing sequestrant and instead using non-phosphate ones. Possible with those to achieve the same? I have a pool with a lot of organic material anyways, so I try and keep the phosphates in check to avoid algae (though I know that view is not entirely popular on this board ).
    Thanks!
    Jul 2009
    Houston, Texas
    9,377
    I don't know if another type of sequestrant will work as well. If you keep the chlorine high enough the phosphates are not going to be a problem. If you don't use an effective sequestrant you won't be able to raise the FC high enough to prevent algae without causing the iron to come out of suspension and stain the pool.
    Love TFP? Become a
    TFP Supporter!
    JoyfulNoise's Avatar
    May 2015
    13,186
    Is it possible to use a chemical like ProTeam Metal Magic which converts the dissolved metals in the water into insoluble metal particulates which are then captured in the filter?
    I've seen it mentioned in a few threads on TFP but don't know much about its effectiveness and impact on a filter (you might need to replace cartridges when done treating the water).
    It might lower the over metal concentration in the water to make it easier to raise the chlorine back up again.
    Matt
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by jeffbg View Post
    If you are keeping phosphates low to prevent algae, presumably because you want to have a lower FC/CYA ratio than recommended here at TFP or you have recurring yellow/mustard algae or you just want more insurance because you don't think you can maintain the appropriate FC/CYA level, then yes you wouldn't want to add phosphates to the pool via an HEDP-based metal sequestrant. The issue is that HEDP is somewhat resistant to chlorine breakdown, unlike EDTA for example, so you'd have to find a non-phosphate metal sequestrant that both sequestered well and didn't break down too quickly from chlorine. Though that may exist, we don't know of a particular brand that does that well.
    Jul 2015
    Pasadena, CA
    9
    I am a newbie and just successfully completed the AA treatment for iron stains that had built up over the last 2-3 years; I always attributed the stains to the neighbors' two oak trees that almost overhang into my pool. If you have oaks, you know what I am dealing with. I have a salt pool with a salt generator (swg) and after I completed my AA treatment, i used Jacks Purple stuff as the sequestrant. I have no idea what this stuff is but my pool looks great and it helps keep it 100% stain free. In my case, i added about 150% more of the Jack's than I needed to help keep stains from returning; i figured more was better with this stuff and since i know i have the phosphates anyways with the oaks, oh well.
    From what i can gather, phosphates are a non issue IF you keep your cl in line with your CYA. You haven't been read the riot act yet but until you post your numbers, the advice here is going to be limited to what your specific pool parameters are. First thing i did was buy my taylor k2006 and i love this tester and knowing my pool parameters has made the info on this site invaluable to the way my pool looks now.
    In my case, I have a serious CYA level of 150 so I have to keep my chlorine up and at the same time balance it so it's not too high to redeposit the stains. Jacks purple stuff has phosphates but as chem geek has pointed our over and over in his posts, it's a non-issue if you keep your cl in line, phospates can't feed algae if you have chlorine in the pool. yes Jack's is more money, but hey, isn't that what a pool is for, to throw money into?
    Finally, as to your re-staining issue, that wasn't my issue. After the AA, mine was cloudy water. This lasted almost 2 weeks and I was really getting worried. I drank a lot of wine to have patience (thanks JasonLion), back-washed almost everyday and added bleach at a really really slow rate (don't use scented/non-splash). I was able to do this b/c of the algcide i added before starting the AA treatment. My pool finally cleared and I am still balancing cl/ph/jacks/and filter run time. I think after an AA treatment, each pool is going to be different and it sounds like a pool drain for you or paying the extra monthly expense for a good sequestrant; w/o which your stains will probably return. What i got from this site was patience in adding the cl and giving the process time to work.
    I live in SoCalif so a pool drain per wife is out of the question; Jacks it is!
    Good luck
    20k gal 14 x 40 gunite, raised spa with spillway, Pentair Intelliflo Variable Speed Pump
    Hayward pro grid DE, Raypak RP 2100 heater
    Purelink swg salt cell & Aqualink RS one touch control
    Barracuda G3 pool sweep, Taylor K-2006 test kit
    "The bigger the hammer, the smaller the brain!"
