Thread: Adding cya
    Jul 2015
    Parma heights, ohio
    3
    Adding cya
    I am trying to bring my cya level up, while trying to be sure not to add too much- how soon can I test the water after adding the cya to know the accurate level of cya?
    above ground-24' round. Vinyl liner. Intex sand swg filter.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Adding cya
    Quote Originally Posted by Deblzap View Post
    About a week, unless you use the liquid stuff, in which case, after 24 hours or so.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Adding cya
    ^^^What he said about when to test after adding CYA.
    Oh...and...Welcome to TFP!
    Casey's Avatar
    SW PA
    10,446
    Re: Adding cya
    Welcome to TFP! Hope you enjoy the site and especially Pool School!
