Thread: Proof this method works
    Cool Proof this method works
    June 2013. Cya level of 155. Constant algae problems, adding Dichlor, using chlorine pucks in auto chlorinator.
    Began reading TFP and the relationship between cya/chlorine.
    Rest of summer did partial drains 3 times and switched to liquid chlorine. Had some trouble with PH getting high. Got the cya down to about 90.
    Summer 2014 cya of 60-70 after winter . Had leaking auto chlorinator removed (against pool builders wishes!). One algae outbreak when I let chlorine get too low during week of rain and no swimming.
    Summer 2015 cya of ZERO after another winter partial drain and much snowfall. Added stabilizer to level of 30-40. Add 1/2 to 1 jug of chlorine per day as needed by testing. Have not had algae despite an incredibly rainy June where we drained the pool down a few inches every other day and had to add more stabilizer because of all the rain replacing the pool water. PH is perfect at 7.4 and hasn't moved all summer.
    If you are reading pool forum and wondering if this method works, I can tell you IT DOES. If you test and know your levels your pool will not be fighting against you all season. You will enjoy having a pool again!
    Thanks TFP
    18'X 36' Free form vinyl, 8' - 3'deep, Pentair 1.5 hp pump,Sta-rite 3.14 hi rate sand filter, pool frog and New water online chlorinator , 3 deck water shooters, deck solar heat, solar cover
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Proof this method works
    Great Post!
    enjoy!
    Divin Dave,
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Great post!
    Is it time to update the signature and remove the Frog and chlorinator?
    I say to everyone, if the site has been valuable to you then possibly support us: CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Support the site
    38,284
    Congratulations on taking control
