Thread: Will My pH Always Be High?
    Apr 2015
    Pasadena, CA
    56
    So, I have an above ground spa attached to my pool, and filter it everyday with water pulled from the pool which in turn spills over back into the pool. I know that in order to lower your TA you would add Muriatic to bring your pH down lower than normal, AND then aerate the pool to only bring the pH back up. So my question is, since I'm always aerating the pool with with my spillover, am I always going to be fighting a high pH? I've only had the pool for 7 months, and that seems to be the case. Any suggestions?
    22,000 gallon IG plaster pool, raised spa w/spillover, variable speed EcoStar pump, natural gas heater, 60 SF DE filter, SWG (all Hayward), AquaLogic automated controller, Kreepy Krawly, TF-100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Will My pH Always Be High?
    Yes,
    Can you post a set of numbers and let us see what your overall picture is please?
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,057
    Yes, you will.
    Eventually you will work the TA down enough that the pH will only need adjusting once a week or so. I throttled back the amount of water through the spa and also capped the air intake with the cap from a can of spray paint, which reduces the aeration.
    Apr 2015
    Pasadena, CA
    56
    Here's my latest set of numbers from this morning.
    FC 4.5
    CC 0
    TA 100
    pH 8.2
    CYA 70
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,196
    Well, it looks like the pH needs to come down and the TA needs to go up, unless the TA is a typo.
    Support the site
    Apr 2015
    Pasadena, CA
    56
    Oops, yep had a typo in the TA. Fixed now.
