Thread: T-Cell Cable/Sensor Open Chlorinator1
    Feb 2015
    Magnolia, TX
    25
    My Omnilogic has an alarm as in the title: T-Cell Cable/Sensor Open Chlorinator1. Its labeled as "auto", meaning I cant delete it. The chlorine levels havent changed so the SWCG appears to be making chlorine. I've tried running the pump without the SWCG being on to see if that would clear it but no change. What does it mean? For that matter, where can I find a list of Omnilogic alarms and their definitions?
    Its a T-cell 15 with about two months under it.
    19k inground w/raised spa, Hayward Omnilogic, Tcell-15, Tristar 1.85hp VSP, 250MBtu heater, C4030 filter
    38,251
    Re: T-Cell Cable/Sensor Open Chlorinator1
    After a little searching, I was not able to find an explanation of error codes.
    From the name, I would think it is pointing to a problem with the cell connection (cut wire or something). I think I would first disconnect the SWG cell and reconnect it and see if that helps. If only 2 months old, seems like you should still have warranty coverage.
    You could try PMing Hayward Pool.
