Results 1 to 12 of 12
Thread: Filtering problems
    Jul 2015
    Hampshire uk
    7
    Filtering problems
    I'm a new owner of an old pool so I'm very new to a lot of what goes on with running one.
    I went through the opening of the pool at the start of the season in May, which seemed to go okay but I noticed that I needed to vacuum the pool out again a lot quicker than I thought. I went on like this for a while then noticed that the inlet was throwing dirt back in to the pool and has been getting worse since. So I changed the sand, checked the laterals and replaced the spider gasket (which was extremely worn). Because I had to wait a while the pool didn't get pumped so it went green but I've been able to get that back to a cloudy blue.
    Unfortunately the pool is still not filtering correctly. I've just tried to vacuum it which started out fine but after a minute or so the pump began struggling and the pressure dropped. I turned it off then back on again and it threw everything back into the pool via the inlet and the pressure returned to normal. It may be worth noting that I had a problem priming the pump so I flushed out the skimmer pipe a few days ago and then it primed fine.
    Is there something else I should check?
    Many thanks,
    Nick
    10500 Gallon, 28ft x 14ft, in ground vinyl pool, tropical isle gas heater, midas multiport and I'll find out the rest!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,515
    Re: Filtering problems
    When you were putting the sand back in did you make sure you did NOT get ANY sand down the pipe? Did you fill up the filter 1/2 way with water before you put the sand in? Did you use GREAT care in putting the sand in?
    If you are not 100% sure of these questions you might want to check to make sure your filter does not have a cracked lateral or sand where it does not belong.
    Kim
    38,290
    If the pool is green and you are trying to vacuum up live algae, it is not surprising that the pressure rose and the water flow slowed down because the filter was doing its job ... catching stuff in the water.
    You can NOT clean up a green pool with a filter as the algae will continue to grow. You need to follow the ShockLevelAndMAINTAIN Process to kill the algae faster than it can grow and then the filter can capture the dead algae.
    30,421
    +1 what jblizzle said. A filter will pick up the debris you send to it. In your case, it sounds like it is filling up and, when it can't hold anymore, it overflows and spits it back out.
    You should SLAM your pool and get it free of algae and your filter will go far longer without needing cleaning.
    Jul 2015
    Hampshire uk
    7
    Thanks Kim. I covered over the pipe with tape, put water in before and put the sand in gradually. I watched some videos showing the process and copied that. If I get the time later in the week I'll empty the filter to double check the laterals.
    Jul 2015
    Hampshire uk
    7
    Thanks jblizzle. The pool is no longer green, but cloudy I'm pretty sure everything is dead and I'm keeping it clear of leaves and other organic matter. When I tried to vacuum it yesterday the water pressure dropped, not rose. I think there may be a problem with the multi port and I've got unfiltered water leaking straight back to the water outlet to the pool, any idea how I could check that?
    Many thanks
    Jul 2012
    Tallahassee, FL
    30,515
    Have you backwashed your filter?
    When you backwash you need to rinse before you put it back on filter.
    When you move your filter lever you should only move it in one direction. I go clockwise. This helps the gasket not get pinched or messed up.
    Kim
    Jul 2015
    Hampshire uk
    7
    Hi Kim,
    I have regularly backwashed as needed and rinsed before returning to filtration.
    There is a lot of free play in the handle when you depress it before you feel the tension of the spring is that normal or does it point to the spring being defective?
    Nick
    Jul 2012
    Tallahassee, FL
    30,515
    I am not sure. Sorry
    Kim
    Oct 2007
    Cedar Hill, TN
    251
    Quote Originally Posted by UKnick View Post
    Hi Kim,
    Nick
    Might have to replace the spring.
    My new spider gasket came with a new spring. (The old one was broken!!) I had the same problem
    Make sure the spider gasket is in the correct location, and the seal is in the right place.
    Good luck
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Jul 2015
    Hampshire uk
    7
    I've just ordered a new multiport of the same model as it worked out only a few pounds more than buying the spring, washer and 'o' rings and I'll replace the whole top assembly and let you know how it gets on.
    domct203's Avatar
    Jun 2015
    CT
    3,587
    Many thanks
    You can't guess with algae, how did you determine "everything is dead"?
    ......... You should SLAM your pool and get it free of algae and your filter will go far longer without needing cleaning.
    That's good advice right there!
    http://www.troublefreepool.com/conte...tain-shockingl
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
