Results 1 to 11 of 11
Thread: My husband turned off the pump for 5 days! HELP!
    May 2014
    Raleigh, NC
    19
    My husband accidentally turned off our pool pump and consequently our SWG before we left town for 5 days. We came back to a pool with 0 chlorine and a slight green tint. Water is clear. We started the the pump and SWG and added bleach.
    FC 3.5
    TC 0
    pH 7.5
    TA 60
    CYA 51
    CH 235
    temp 84
    What else do we need to do to clear the water and when can we swim? This is only our year with the pool and the first time ever turning green, so I am at a total loss.
    Thanks!
    18K gal 15x35 IG fiberglass w/waterfall & 2 deck jets, Pentair Clean & Clear 320 cartridge filter, Pentair IntelliFlo VS-3050 pump, Pentair IntelliChlor IC20 SWG, Polaris 9450 Sport robot, Pentair Rainbow Automatic Chlorine Feeder (for winter), built 4/14, Taylor K-2005 + FAS/DPD
    Azgirl71's Avatar
    Apr 2015
    Sierra Vista, Az
    2,586
    Re: My husband turned off the pump for 5 days! HELP!
    Sorry that happened, but you need to SLAM until you pass all criteria.
    Pool School - SLAM - Shock Level And Maintain
    Lisa
    Intex AG vinyl 15' x 48" 4,300 gallons due to skimmer install, Krystal Clear SF pump combo 2800 GPH, Krystal Clear SWG, Pool Blaster Max vacuum, Hayward thru the wall skimmer, TF 100 test kit with speed stir, K 1766 Taylor salt test, My SLAM Process
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Dang husbands! Oh wait, that's me. Yep, time to SLAM.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,421
    You caught it in time. Breath and SLAM.
    You can swim if your FC is just under the CYA level for SLAM. It will slow down your clearing up but will be worth it just to be able to swim!
    Pool School - Chlorine / CYA Chart
    Let us know how it is going!
    Kim
    Apr 2010
    Central NJ
    227
    Nice to see both of you have accounts here. Turn off the SWG while slamming.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Bleach and brushing will fix it up quickly.
    Brushing scrubs the slimy biofilm scab off the algae so the bleach can get in and kill it and it also helps circulate bleach-laden water to areas with poor circulation. So pop a few Motrin in advance, raise FC to 20, and make a lap around the pool with the brush. Have a beer. Recheck FC and raise it to 20 again. Make another lap with the brush. Have another beer. Repeat as needed. You can have the pool a blue-grey color the first day. With the filter on all night, don't be surprised if you come out in the morning and it looks clear. That's when you vacuum. Move the head slowly - sneak up on anything and let the suction draw it towards the vacuum rather than stir it up by pushing too fast.
    A couple days will fix it up.
    May 2014
    Raleigh, NC
    19
    It's looking good! We ran the robot, added more bleach, scrubbed. It only has a slight green tinge in the deep end now. Y'all are the best! Need to do the OCLT in the morning, but at the rate it's clearing, I'm guessing we'll be good to go.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Dont rush it. If you say green, you arent ready for oclt. Just a few more days should do it.
    May 2014
    Raleigh, NC
    19
    It was perfectly clear by 4pm. That seems awfully fast, but there's not even the slightest tinge of green left.
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by booksfan View Post
    That's great if it is, but you should still run the overnight loss test and ensure the CC is also below .5. Those of us who've been around here a while have seen too many people stop too soon. It's not unlike taking antibiotics to kill an infection. You don't stop after one day just because you feel better. If you do, you'll relapse. You keep taking them to be sure your infection is cured. So too with the SLAM process. Be sure your pool is cured.
    Casey's Avatar
    SW PA
    10,423
    If you're pool is Crystal clear today with no cloudiness, I'd do an OCLT tonight n check it first thing tomorrow morning. Let us know if you pass.
