Thread: Hayward max flo pump questions
    Oct 2013
    Baton Rouge, LA
    86
    Hi,
    1. I am confused on how to use the 3 timer setting on my pump. Is it possible to use 1 setting or does the pump automatically switch between the 3 settings?
    2. How do I get it to run 24 hrs? I set the start and stop time as the same time but that didn't work to disable the timer.
    3. When I come home from work the display is reading "Idle" or "1dle" can't tell is its a 1 or an I. Anyone know what that means?
    Thanks guys.
    30,000 gallon In-Ground vinyl, small fountain, Polaris 9300 robotic cleaner
    Jul 2015
    Florida
    48
    1) set the 2 timers you don't want to use to start and stop at the exact same time. 12:00-12:00. This makes the logic ignore these timers.
    2) To run 24 hours you need the timer to start at 12:00am and end at 11:59pm.
    Hayward has the manuals on their website which includes code errors.
    15x28 free form in ground crystal Crete
    10-12k gallons
    Hayward aqua rite TCell 9 SWG
    Hayward Maxflo VS pump
    Hayward Star-Clear C1200
    Oct 2013
    Baton Rouge, LA
    86
    Re: Hayward max flo pump questions
    Great thanks so much for the help.
