Thread: AG Wall Padding and Gaskets
    Jun 2015
    Grantsville, MD
    13
    I'm getting ready to install my new pool liner and I will also be adding the foam wall padding.
    My question is should install the skimmer, light and return gaskets between the liner and the padding or between the padding and the pool wall?
    Does it matter?
    2004 16' X 32' X 5 1/2' deep end AG KAYAK Pool appx 19,000 gal
    1HP Sta-Rite pump with a PLM 100 cartridge filter system
    Jun 2015
    Grantsville, MD
    13
    Re: AG Wall Padding and Gaskets
    I just googled it and it's recommended that the foam be trimmed about 1" around where the gaskets will be placed.
    So it's between the liner and the pool wall. When trimming the foam, go 1” larger all around so the wall foam does not interfere with the gaskets and face plates
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    right!
    Divin Dave,
