Thread: how do I light the pilot light on my Laars Lite Teledyne LLG model 175 Pool Boiler?
    I have a Laars Lite Teledyne LLG heater Ė itís about 18 years old Ė model number 175
    The pilot has gone out and I canít remember how to relight it!
    Just left of centre there are two rectangular/square cross section knobs. The one on the left is white with a sort of crescent with a bulge moulded into the top of the knob. To the white knobís right there is a red knob with a circle shape moulded into the top.
    On the right side of the boiler is a narrow cylindrical knob which points out horizontally
    I am pretty sure that lighting the pilot is something to do with these three knobs
    How do I light the pilot?
    Can you also tell me where the pilot itself is Ė I remember that is quite inaccessible.
    Regards
    Matt Stainer
    Matt Stainer - pool holds 10,000 gallons
    Jun 2015
    Wildomar, California
    423
    Re: how do I light the pilot light on my Laars Lite Teledyne LLG model 175 Pool Boile
    The pilot assy is located on the burner farthest on the right. If memory is good, the valve button is set to pilot and the red button is either pressed to pump gas to the pilot or you press the red button to allow you to set the knob to pilot. Some of the earlier heaters had a sparked to ignite the pilot. You might need to use a match. Make sense?
