Thread: Cleaning debris from suction inlet in skimmer, ideas?
    Jul 2015
    Jackson NJ
    7
    Hi!
    Apparently there are some long needle pine trees somewhere on our property we've recently moved to. After vacuuming and removing the hose from the skimmer suction inlet I found a bunch of pine needles, three needles clumps, hanging out at the bottom bend. I tried to stick my fingers in to remove them. I very gingerly tried bbq tongs. I tried forceps. I've had no success. It is not totally clogged. There is still good suction. They need to come out though, preferably out the path they went in. Any creative ideas on how to remove these? They were sucked up by the vacuum. There were so very few, I thought the vacuum could handle this. I won't do that again, instead I will net them out. How have you removed them?
    Thanks!!
    Roxanne
    24-26K gal, IG concrete/plaster 08-09, DE filter, 1.5 HP, Polaris 380, well water, Jackson NJ, 1st time pool owners. Don't have all numbers. Not a multi port valve. Thanking you all in advance!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Cleaning debris from suction inlet in skimmer, ideas?
    shop vac?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2015
    Jackson NJ
    7
    Thanks Paebeder! For some reason I didn't think I could apply negative pressure there. But that's ok?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Quote Originally Posted by Roxanne1 View Post
    Open up the pump strainer and flush backwards with a garden hose from there.
    Jul 2015
    Jackson NJ
    7
    Thanks Richard!
    Sorry for this tediousness... So I pull out the strainer basket and take a garden hose and direct the water into the pipes and eventually toward the filter?
    Richard320's Avatar
    Jan 2010
    18,984
    Thanks Richard!
    Nope. You open the p[ump lid and lift out the basket and stick the hose into the opening where the water normally comes into the pump and flush backwards out the skimmers. If you wrap the hose with a rag you can wedge it in pretty tight and any pine needles in the plumbing should get pushed out where you can grab 'em. .
