Thread: Slam/ cleaning pool
    May 2015
    Nacogdoches texas
    21
    Slam/ cleaning pool
    The floor of my pool looks dirty but it's not dirt- it's like an algea that poofs up when disturbed. I added bleach but I'm not familiar with slamming pool. Here are my numbers- please advise on what tondo next to clear it up.
    Fc: 9
    ph: 8
    cya: 80
    Intex 22'x52" above ground pool with cartridge filter and Intex SWG
    k2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Slam/ cleaning pool
    During normal maintenance if is important to maintain PH between 7.2 and 7.8. Here are the Recommended Levels for your pool.
    To verify if you have algae you can raise FC above 10, turn off your swg and Perform the Overnight FC Loss Test (OCLT).
    If it doesn't pass the OCLT then here is the process to SLAM - Shock Level And Maintain your pool.
