Results 1 to 7 of 7
Thread: Solar lights?
    chezhed's Avatar
    Mar 2009
    Mission, TX
    37
    Solar lights?
    Doea anyone place solar lights around their pool in the landscaping areas? I found some at a yard sale last year that we liked and put new batteries in them and they do add a nice effect in the evening but just aren't quite bright as we would like. Wondering if anyone can recommend some GOOD ones. thanks
    11,000 gal + overflow spa, IG gunnite, Pentair 48FNS DE filter, Hayward SP3210X15 pump, CompuPool CPSC36 Chlorine generator, pool valet w/5 zones, Pentair LP heater
    Feb 2008
    Denton, TX
    5,061
    Re: Solar lights?
    I've tried three different types in the past and have yet to discover the ones that seem to fill the bill. Now the last set I bought from Lowe's had LEDs instead of regular bulbs. They seemed to stay lit longer than the regular ones did, but they really weren't much brighter. Brightness issues seem to plague all of these sets. Wish I could help you there but even I haven't found the solution yet.
    phenwick's Avatar
    May 2009
    Metro St. louis Mo.
    11
    Re: Solar lights?
    I have 30 + lights of different configurations. here are some things I've learned:
    They are just accent lighting, don't expect to much from them for general illumination;
    The really need to be in full sun all day; Keep the solar panels wiped off.
    The batteries supplied are usually junk right out of the box. I replace them with Sanyo Nicad 700mAh Cadnica cells available online from battery suppliers or hobby sites.
    I also have several chargers to condition the batteries back into shape when needed. Also avoid the replacement batteries on the hooks with the solar lights. More junk.
    Metal housings are better than plastic (durability issue) and SS is better around pool areas. But I do have plenty of plastic ones.
    The Malibu spot lights that run three lights off a shared solar panel perform nicely.
    Dave
    22,000 IG vinyl; Swim Out; Sand Filter
    Jun 2007
    NC
    255
    Re: Solar lights?
    Quote Originally Posted by 257WbyMag
    So far, what we've found is that if they have a single LED they are way, way too dim = don't bother.
    If they have 2 LED's they might work but probably not.
    If they have 3-5 LED's they will work, but the battery life is too short.
    --That part makes no sense as LED's use very little power!
    Triad Region of NC
    18x37 Vinyl IG (24,000 gal.), BBB & GoldLine AquaLogic PS4 SWG, Hayward 1 HP Superpump / Hayward Sand Filter / Polaris 280 cleaner / 6 deck jets / Sheer Descent Waterfall (in coping) / Brick Red Concrete Coping / Stamped Concrete Deck
    Lots of oak trees, maple trees, *and* leaves!
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    Re: Solar lights?
    shellsingleton had come across some nice solar led spotlights:
    added-some-accent-lighting-for-my-palms-t11402.html
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
    Vero Beach, FL
    462
    Re: Solar lights?
    I bought these from sams club http://www.samsclub.com/shopping/naviga ... pCatg=6126
    18 for $100. They are stainless steel and real glass with minimal plastic. I need the stainless because my irrigation system keeps them wet and the sun is very hard on plastic. The tube is stainless and the metal spike that goes into the ground is aluminum (I think). They are well built for $6 each. I find they are bright enough for me and cast a nice pattern on the ground, which I like but some may not because it is not an even lighting. The only negative is that they came with only 350 mAh batteries. I have had them only a few weeks, not in direct sunlight and they have worked fine and are still lit at 5am. I'll replace the batteries with Nimh ones when these go out.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Re: Solar lights?
    We are on a couple of acres out in the boonies. Lighting the house and deck area - way too costly. We have been purchasing solar flood lights. Don't bother with anything less than 3 LED bulbs. We currently have 8 flood lights on the front of the house, don't need anything else there. On the triple level deck we are currently using another 8 attached to the post and beaming towards the floors of the deck and the stairs. Out in the garden area are another 8 flood lights and towards the end of the property we have started to use them. It's about 1/2 an acre of heavy trees back there so not much sun coming through there. We get the lights at Menards, 2 of them for roughly $14.00 when on sale. We prefer the individual lights as apposed to the Malibu 3 pack with wires to the charger. Generally change batteries every couple of years.
    27 ft round 52" wall
    Cartridge filter
    Above Ground
    2 hp Hayward pump
    Using 2 2x20 solar panels
