Thread: Need some help
    Jun 2015
    Columbus Indiana
    6
    Need some help
    Finally got the chlorine down. It's still a bit high but no longer orange color when I test it.
    PH- 7.2
    FC-10 ppm
    CC- 0
    TA-70
    CYA-75.
    I don't know how to get my CC Up or how to get my TA up or what to use to get PH up
    45,000 gallon, in-ground pool. Hayward-200 sand filter. Hayward chlorine feeder.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Need some help
    Welcome to the forum
    You don't want the CC to come up, so perhaps you mean something else? 0 CC is actually good. Do you have a Chlorine drop test that turns pink, or just the one on the block with pH that turns yellow?
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    Re: Need some help
    Welcome to TFP! As long as your PH is stable there is no need to adjust your TA. 70 is good. 0 CC is the right number!
    Have a look at this, Pool School - ABCs of Pool Water Chemistry
