Thread: First FAS-DPD Test
    Jun 2015
    Forest Hill
    20
    First FAS-DPD Test
    So, after all my pool repairs and draining/refilling, I finally completed my first FAS-DPD test. Findings seem good to me for SLAM levels, please see below. Also, my pool floor is clean, there is virtually nothing floating on the top, and my water seems to be super clear. Still ugly, but that is due to a stained and nasty liner (to be replaced next year).
    FC - 11.8 (25mil sample used)
    CC - .8
    pH - 7.3
    TA ~ 80
    CYA - Still waiting to retest. Last time, the reading wouldn't show using our test kit (too low). Added CYA 100% this morning, and will retest Thursday of next week.
    Also, my cheapo water thermometer is reading about 85 degrees F
    If anyone has advice for me, I would greatly appreciate it.
    Forest Hill, MD \ AG 24 FT Round ~ 13,000 Gal \ Hayward Power Flo LX 1.5HP w/ Hayward S210T Pro Series Sand Filter\ Perhaps 2009 \ Taylor Complete High K-2005 Test Kit \ Well filled
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: First FAS-DPD Test
    are you in the middle of a SLAM? if so, your FC looks good. as soon as the CYA is dissolved, your FC should be based on that. usually takes me 1 day to dissolve, but don't test for a week as you know.
    no point in testing pH if your FC is over 10, the reading isn't accurate.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    If you use just 10mL to test your FC, each drop would be 0.5 (in other words divide the drops by 2) This saves on reagents.
    Yippee
    Jun 2015
    Forest Hill
    20
    We just started to SLAM on Friday morning. Tested everything before starting the SLAM.
    Midnight Friday night, FC level was 12.2 Going to test again in the morning to see if we dropped any. Thanks Yippee, we will be switching to that method. Thought the more accurate .2 ppm would be better, but not after counting out about 50 drops. Dont think the .2 vs .5 ppm will make that much difference.
    I did notice before that even with added chlorine, algae was still growing. Could this simply be due to not enough FC? Our FC was pretty low, even with the addition of a full gallon of bleach.
    Thanks, folks!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,103
    Yes, algae has this sneaky ability to cloak itself in a slime coat. It's one of the reasons why you read a lot of posts reminding folks to BRUSH BRUSH BRUSH all over and everywhere.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Quote Originally Posted by pabeader View Post
    Beat me to it.
