Results 1 to 8 of 8
Thread: Advice - VS Pump Options
    Jul 2015
    Ottawa, Ontario, Canada
    3
    Hey folks,
    So I have talked with a few different pool companies in my area who all have differing views/opinions. In essence, I need to replace my old Jacuzzi-brand 1.5 hp pump and I am leaning toward the Hayward SuperPump VS or the TriStar VS. I was told the TriStar has more timing options, including a built-in 24 clock, while the SuperPump does not. I do like the idea of internal controls, even though I do have a wall-mount rotary timer. In terms of specs, it is a 22.5K gallon pool with SWG, it has 1.5 inch piping, a Hayward 250k BTU heater, and a Hayward S220-T sand filter. In essence, what would recommendations would you guys make in terms of a new pump?
    Cheers,
    -Patrick
    22.5k gallon inground vinyl liner pool; 3'-10' depth; one skimmer; two returns;
    Jacuzzi 1.5HP pump; AquaRite Low Salt Chlorine Generator; Hayward S220-T sand filter; Hayward 250k BTU heater
    Re: Advice - VS Pump Options
    I believe the new superpump vs comes with a built in clock, the old model (which I have) did not.
    24k gallon inground vinyl liner pool, 8'-3' depth, 2 skimmers, 3 returns, basic 5 chem kit.
    Hayward: DE-60 filter, Superpump VS, AquaRite salt chlorinator w/T-Cell 15, TigerShark QC robot. Jacuzzi hot tub ~350gal. Air blower type, w/8 jets.
    Jul 2015
    3
    Thanks. One of the pool shops indicated that the new SuperPump VS model will have an integrated timer.
    Any one else care to chime in on my predicament?
    Jun 2015
    LI, New York
    24
    My new superpump vs has countdown timers but not a clock. When it powers on it will automatically go to V3 speed for the time I set and then go to V1 speed until power is cut. Works very well with my old mechanical timer.
    30,000 gal IG concrete (Diamond-Brite)
    Hayward 1.5 HP Super Pump VS
    Sand filter
    Taylor K-2006 test kit
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Engineering and Marketing made this change this year. It now has a time clock. That being said, not sure what is in the pipeline for supply.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    May 2011
    Beaumont, TX
    5
    I am happy with my Hayward SP2302VSP. It is very efficient. It has a clock and three separate timers. Each timer is adjustable for time and rpm. You can also set timers to "0" and only use one or two, or, overlap times to continue at a different speed.
    33' Sharkline Matrix, Hayward MaxFlo 2302VSP 1.5hp, FlowVis, Hayward S360t2 33" sand filter, dual main drains and three returns
    Mod Squad pooldv's Avatar
    DFW, TX
    24,492
    I love the pump that I have but it is a lot more pump than you or I need. I also like the Pentair 342001, 1.5hp VS pump
    Pentair SuperFlo VS Pump 342001 | Pentair 342001
    Jul 2015
    Tempe, Az
    123
    I second the SuperPump, but see my post up top about some install tips. Seal it with silicone and make sure it's covered.
    Great pump. My VS has integrated countdown timers for speeds 2 and 3 then returns to idle mode. You can change the speeds and preset run time, but there is no clock. Apparently this was changed on the new version though per my hayward rep but I'm not sure when it's available. You can still run a mechanical timer, but the pump defaults to high speed for 12 hours when it first turns on
    i need to add... More pump is not a bad thing when looking at variable speeds. More flow at lower RPM (translated, lower energy usage) is never a bad thing. With my 28k gallon setup, I only need to run my VS on high if i shock the pool, and for about 4 hours at that. The rest of the time it runs on medium or low and maintains the same flow as my old single speed. I think my SuperPump costs me about a nickel (USD!) an hour....at most.
