Thread: Old pucks... how potent?
    I have some old trichlor sticks (2 years old). Are they still chemically useful. I thought of using them since my cya is finally down to around 30 or so (took 2 years of nothing but BBB for it to come down from over 100!). If they are still good, I could put a couple in the skimmer while I am gone on vacation (1 week) and come back to a pool with chlorine and a bit more cya. Is this a good plan? Thanks.
    10,000 IG vinyl liner pool, Hayward sand filter, Hayward SuperPump (converted to 2-speed), BBB user
    numbers
    BTW, here are my numbers:
    FC 7
    CC 0
    TC 7
    pH 7.6
    TA 120
    cya 35
    Had been keeping FC at 10 because cya was about 50 this spring when I checked... it's now about 35 (yesterday).
    Water looks and feels great!
    30,400
    Those are nice numbers....good work getting everything right!
    Yeah, I'll bet they're still good and that's the perfect application for them. A couple may not be enough to get adequate Cl in there......the CYA increase will be very small.
    Others familiar with sticks may better advise on the dosage but I think you've got a good plan.
    Re: Old pucks... how potent?
    Quote Originally Posted by drband
    Funny...
    I'm considering boosting my CYA from ~50 to ~90. I get a little too much FC loss at ~50.
    26Kgal IG Vinyl liner
    Hayward 1HP Superpump
    Hayward Pro Grid 4800 DE Filter
    thepoolcleaner pressure side cleaner
    Arizona
    924
    I read somewhere that pucks have a shelf life of 3 years, so they should still be good.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Quote Originally Posted by eelhc
    Funny...
    I'm definitely wanting to get back in the 50-60 range to have less FC loss. I had high cya for so long, I just let it go down naturally to see how long it took (2 yrs) and how low it would go. My FC loss level (approx 35 cya and lose about 5 ppm FC daily) requires a bit more daily attention than the 70 cya level did. At 70 cya, I could add 1/2 gallon every other day and still maintain good levels of FC. At 35 cya, I have to check and add clorox every day.
