Thread: Acid and bleach injection points
    travisr100's Avatar
    Jul 2012
    Houston, TX
    151
    I'm getting ready to plumb in a stenner pump for acid and another for bleach. Is there any guidance on how far apart the two injection points should be?
    IG 13,000 gal, WetEdge Prism Matrix Indigo Blue, Hayward C4030 cartridge filter, Hayward Ecostar VS main pump, Hayward Tristar VS feature pump, Hayward OmniLogic, Hayward Sense & Dispense (pH only), Stenner 45MPHP22 bleach, Hayward H400FDN Heater, Hayward Color UCL lights, Pentair LED Bubblers. TF-100 XL test kit. Test Results. Build Thread.
    Mar 2015
    Sugar Land , TX
    424
    Re: Acid and bleach injection points
    I don't see any reason that can not be next to each other just as long as they are NOT injecting at the same time. Usually you will have more than 1 return line going back to pool ( returns to pool, returns to spa , bubblers ...etc ) and you can also install injector on each which would allow you to inject at same time.
    Just FYI my pool is about 4 months old and I have noticed the acid demand going way down. Once I had TA in line and turned my spillway down ( aereation ) it has been more stable. They say as gunite / plaster cures the demand will go down and stabilize. I guess my point is you might not need to spend the $$ on another Stenner just for acid. Use the extra $$ for flying!!
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    travisr100's Avatar
    Jul 2012
    Houston, TX
    151
    Hmm. That's a problem. Single return back to the pool. Acid will be in S&D so won't know when it dispenses. Bleach will be on timer.
    Money already spent at this point. I guess just keep them as far away from each other as possible? I have a few feet to work with.
    Mar 2015
    Sugar Land , TX
    424
    Oh I thought you were going to gave 2 separate tanks, bleach and acid, running off 2 separate Stenners. Just noticed you have a water feature. Is it going to be automated to come on? If so you could inject at that point and the return for the other(acid). Just program pool to also run to mix the bleach when water feature is finished injecting.
    travisr100's Avatar
    Jul 2012
    Houston, TX
    151
    That's correct, two separate tanks and pumps. Hmm, that's a thought.
