Thread: Propane vs Electric Heater...
    TheBraLady's Avatar
    Jun 2015
    Concord, NC
    177
    We are about a week out from the start of our build and I am so conflicted about either a spillover hot tub or a free-standing spa. One big part of the decision is how to heat the spillover. We do not have natural gas or a large propane tank currently. I'm wondering about electric? I understand that the gas is much, much quicker, but boy does it sound really expensive! A local gas company said that the 400,000 BTU heater my builder quoted will most likely use 4 gallons per hour! Eeeekkkk!
    I would love to get some feedback...
    Thank you in advance!
    Sara
    Pool Completed 8/2015 18'x36' Gemini shape 3.5' - 8', 19,200 gal IG vinyl, Hayward Max-Flo 1.5 HP 2-speed pump, Hayward Pro Series 300-lb sand filter, Hayward AquaPlus SWG, NO Autofill, Dolphin M400 robot, Taylor 2005 test kit, 434 gal Bullfrog A7L spa
    22,553
    Re: Propane vs Electric Heater...
    If you're just going to heat the spa and given your climate, a heat pump should work fine. It won't be anywhere near as fast as propane, and I wouldn't even consider it if you plan on heating the pool, but it'll work ok for the spa.
    You'll need to have the spa plumbed so that it can be operated as a stand-alone when you want to heat it.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Quote Originally Posted by TheBraLady View Post
    Sara
    Sure it will use 4 gallons an hour but it won't take long to heat the spa. Once you isolate the water to just the spa and turn the heater on, it won't take very long to heat it up. Then to maintain the temp won't be very much either. Don't let the gallons per hour scare you. Unless you decide to use the heater to heat the pool. Then you better consider getting the kids piggy banks and break them.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Mar 2015
    New Orleans, LA
    81
    Gas is the way to go. Heat pumps don't work very well when it is cold and that is the best time to use the spa.
