Thread: Adjusting Chlorine Output with Autopilot
    Jul 2014
    Shawnee/KS
    15
    I'm not sure why but if I set the chlorine output to say 50% then recheck the display the next day the % output often is at a different amount. Is this unit made to auto-adjust the chlorine output? No one else touches the unit.
    IG 21,600 vinyl gal 38'x20' 3.5'/8', Pentair Sand Dollar SD80 filter, Pentair 1.5HP pump, Auto Pilot Salt Chlorine Generator RC 28. 2 LED lights, 2 bubblers.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Adjusting Chlorine Output with Autopilot
    Is there a programmed schedule that has the output set at a different %? If so, whenever it hit the next time slot in the program settings, it would set to that %.
    Isolated Spa - 345 Gallons
    Jul 2014
    Shawnee/KS
    15
    Received a response from the manufacturer.
    "Thank you for contacting us. The AutoPilot units have temperature compensation. After you set the unit percentage, if the water temperature goes up, the purification percentage will go up. If the water temperature goes down, the percentage will go down. Warmer water typically needs more purification."
