Results 1 to 9 of 9
Thread: jandy system Im lost
    May 2014
    amsterdam ohio
    26
    Installed my aqua link RS salt system turned the power on an the chlorine generator interface is blank. Also the pump will not start. As for the pump I'm not sure but I suspect I don't have the dip switch set properly. I think the number 2 switch should be set to on. Is this correct? The pump is a 1.0 variable speed pump and the control is aquilink rs Thanks
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    Love TFP? Become a
    TFP Supporter!
    May 2014
    amsterdam ohio
    26
    Re: jandy system Im lost
    please i will not hold anyone liable if dipswitch 2 should be turned on
    22,539
    I'm not sure that switch 2 has anything to do with a variable speed pump.
    Is anything connected to aux2 relay? If nothing is connected to aux2 then it shouldn't matter if it's on or off.
    May 2014
    amsterdam ohio
    26
    nothing connected to aux 2
    22,539
    Then it won't hurt anything to switch DIP 2 on.
    Mar 2015
    New Orleans, LA
    81
    The SWG will not turn on if the pump is not on. They should get power from the same relay. Check the breaker. The new GFI breakers don't looked tripped. Throw it back and forth a few times.
    May 2014
    amsterdam ohio
    26
    Turns out that the dip switch has nothing to do with the salt system or the pump turning on. Finally after several calls to jandy only thing I could get out of them was call a service center. They said they could not answering any electrical issues do to liability Ok I can understand that. Made calls to three different service centers that were at least an hour drive, to far out of there service area. Last call to jandy I begged them to help which turned out to be the wrong information but I did appreciate the help. Finally after several hours and walking away and mowing the yard and thinking it hit me (to long to explain) IT WORKS! Thanks for the replies they did help
    22,539
    Glad you got it working, but I'd really like to know what it was. Maybe sometime when you feel like typing, you can give us the readers digest version.
