Thread: What should I do about this algae?
    Kamil's Avatar
    Nov 2013
    Lancaster, PA
    45
    I have a 28K gal vinyl pool
    FC = 2.5
    pH = 7.6
    TA = 80
    CYA = 55
    Temp = 78 deg. F
    There is green algae in the pool. Please see the pics.
    Flickr - Photo Sharing!
    I brushed it away but it came back, I had FC up around 9 but the algae keeps coming back (FC is low now... I'll have to add more chlorine) Should I shock it with 30 FC and brush it? Should I stop the filter while I'm shocking? What if some of the algae got in the sand filter because I ran the vacuum and sucked up some of the algae? But I did backwash the sand filter.
    Please let me know what I should do next.
    Kamil
    28K gal installed 1985, IG Vinyl, Jacuzzi Sand Filter ST-24 (60 GMP) DVK-7 Valve, Jacuzzi Magnum Plus pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: What should I do about this algae?
    It is time to Pool School - SLAM - Shock Level And Maintain your pool to kill your algae. If you want to swim while you are SLAMing just keep your FC a little below shock level and swim. We swam every day for a week and half while slaming earlier this summer, our cya was 70 and FC was 25-28. If your water is clear it shouldn't take too long, maybe a week.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Quote Originally Posted by Kamil View Post
    What if some of the algae got in the sand filter because I ran the vacuum and sucked up some of the algae? ,
    well, that's kinda the point of the filter
    yes, you want to filter out the alive/dead algae. the water flowing thru the filter will kill the algae, no worries there.
    next step as mentioned is the SLAM. do you have one of the recommended test kits? you will need it.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Kamil's Avatar
    Nov 2013
    Lancaster, PA
    45
    Thanks guys... I have FAS-DPD Chlorine test kit... that's the one I used to take all the tests. I got some DE and Chlorine. I guess I'll add some DE to the skimmer, then vacuum up the algae, then add chlorine... then brush the entire pool.
    Kamil
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    I'd add the chlorine FIRST, then concentrate on brushing and DE.
