Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: Am I using too much Chlorine
    Jul 2015
    Coventry, CT
    22
    My last post got me up and running with my new pool. Thanks again everybody. Quick question though. Things have stabilized and I have been following the advice I got. My pool gets 10 hours if sun easily. Maybe more? I just moved in a couple weeks ago. My CYA level looks to be between 50 and 60. Every day at 5 pm I test the pool. My FC is at 4ppm. I add 20 oz to gain 1 ppm for my pool. I bring it to 8 ppm every night. And the next day it is back at 4 ppm. So that is 80 oz of bleach per day.
    Is this typical? Feels like half a jug of bleach a day is quite a bit. $1.50 a day as I see it.
    Anyway... the water is flawless and pure and clear as I have ever seen water. My last full test results were...
    FC 4 to 8 everyday
    CC 0
    PH 7.4
    AK 100
    CH 120
    Please I would love to hear thoughts on the chlorine usage.
    24' AG (still learning details)
    1.5hp pump
    Clear Water High Rate Sand Filter 22"
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Am I using too much Chlorine
    You could cut back going to 8 as often, and save a 20oz here and there. If your are 60, then 7 FC is your target anyway. People with a lot of Sun lose 3-4 everyday, so it's no unheard of. I'm lucky, and unlucky. I can run near 40 and lose two, but I get some shade, and it's hard to warm my pool until it gets really hot, and stays warm at night.
    What you are doing is good practice because over shooting the target by a point or so frequently really helps keep you further out of the danger zone. Sounds like you have a good grasp of this already so, good job.
    Essential Links:
    brauh01's Avatar
    Jul 2012
    Yardley, PA
    66
    Mojin7,
    Patrick_B's answer is the definitive one. Just thought you'd like to know I'm running about the same numbers and same level of chlorine usage.
    Patrick_B,
    Thanks for the "lose 3 - 4 everyday" comment. I have even more sunlight hours, and was never sure what usage rate to expect.
    Bill
    23,500 gallon IG plaster with pebbles, Pentair FLT FNS 60 DE (160 GPM flow rate), Pentair Model 320 in-line Chlorinator, Jandy Plus HP 1.5 HP pump replaced with AO Centurian 1.5 switchless motor; Aquacal Heatwave heat pump. Method: since 2012 transitioned from "pool-stored" to TFP! Get your test kits here: TFTestkits.net correct link for pool calculator: http://www.troublefreepool.com/calc.html
    22,550
    If that's a 54" deep pool then it's about 13,500 gallons so 80oz is about 4 ppm loss, which is a little high, but not unheard of.
    How confident are you of the CYA test?
    You could bump it up to about 60 and see if that brings the usage down a couple of ppm.
    It also sounds like you may be a candidate for an injection system.
    30,421
    All good advice. I(t's tempting to bump CYA to 60 ppm. That would be my absolute max for a manually chlorinated pool.
    An SWG would allow you to run 70-80 CYA and very likely get a consumption reduction perhaps as low as 2 ppm. That said, the front money on an SWG might be $1k
    Husky25's Avatar
    Jun 2015
    "East of the River" CT
    459
    Where are you getting your chlorine? Is it 8.25% bleach or 12.5% LC? You could cut down on the relative cost by upping the concentration of your chlorine. Of course, that doesn't work if you are already using LC.
    Chris
    Outdoor in-ground 18' x 36' rectangle w/ vinyl liner. 2 returns, 2 drains, single pool side skimmer, ladder, diving board, LED multi-color light, Pentair Cristal-Flo II Sand Filter, Sta-Rite Super Max 3/4 HP Pump, AquaCal R410A heater, SpeedStir, TF-100. Baquacil Conversion of former pool - June 2015, SLAM How-to, Chlorine/CYA Chart
    Jul 2015
    Coventry, CT
    22
    Quote Originally Posted by Patrick_B View Post
    Thanks again Patrick. I followed your advice last time and my pool is ridiculously healthy. I think I may overshoot to 8 less often. Maybe I later storms and high usage only. It's just when I bump to 7 FC I'm down to 3 to 3.5 in 24 hours. Again thank you for the affirmation.
    1.5hp pump
    Jul 2015
    Coventry, CT
    22
    Quote Originally Posted by brauh01 View Post
    Mojin7,
    Patrick_B,
    Bill
    Thanks Brauh. Good to here this isn't too abnormal.
    1.5hp pump
    Jul 2015
    Coventry, CT
    22
    Quote Originally Posted by Bama Rambler View Post
    That's exactly what I'm figuring on. And it feels a little high to add that much every day. I haven't strayed because the water is or seems perfect.
    And actually I'm not super confident in my CYA test. I get 50 to 60 every time but hard to judge exactly when I lose sight of the dot.
    1.5hp pump
    Jul 2015
    Coventry, CT
    22
    If only I could tell if the CYA was 50 or 60. I would bump to 60 if I lower just to see how it works. There is quite a bit of summer left!
    1.5hp pump
    Jul 2015
    Coventry, CT
    22
    Quote Originally Posted by Husky25 View Post
    Hey Husky. I use Great Value from Walmart. 8.25%. I found it for about 2.80 a jug. 128 oz I believe. From what I have seen I "think" that's my best value there. Any other thought on that?
    1.5hp pump
    Husky25's Avatar
    Jun 2015
    459
    Concentrated household bleach typically comes in 121 oz. jugs. Ocean State Job lot sells fresh 12.5% LC for $2.99/gallon. I work across the street from an OSJL in Gales Ferry and in a pinch (read: weekends), I'll go to the one on the Berlin Tpke. Using the Price per Ounce Calculator, you are paying $0.28 per oz. of active ingredient when using bleach (plus tax). 12.5% 128 oz. (gallon) jug at $2.99 is less than $0.19 per oz. of active ingredient. OSJL sells cases of 4 for $11.96. Willimantic and Manchester are closest to you. I suggest picking up a case or two and to make sure it is not a wasted trip, swing by Bidwell for some wings on the way home. .
    Chris
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,323
    I'm in full sun for 7 hours and with recently getting cya down from 70 to 40 I was putting in about 1 gallon of bleach a day. (1 gal = 3ppm for me)
    When cya was 70 I needed one gallon only every 3 days, which I liked, but wasn't fun when I had to do a slam (tons more of bleach than if it was 40)
    So I use my solar cover (blue) during the day now and it uses a lot less chlorine now. Heats the upper 12 inches of water too.
    Dolphin E10 Cleaning Robot.
    Jan 2012
    'burbs of Augusta, Georgia
    7,348
    I don't see $1.50 a day as much to pay for the use of a pristine healthy pool. That's just $45/month. In the heat of the summer.
    What would you be paying if you were buying pool store potions?
    Ellington, CT
    262
    I go to the Enfield store (very high turnover of their chlorine so always fresh) but i guess I could make a case for going to Willimantic if I stop for a bucket or two of wings!
    Mojin7 - You best value for chlorine around here is at OSJL. Here's the guidelines I go by:
    • Buy only fresh chlorine - check the date lot code and buy only if it less than two weeks old
    • Only buy enough for a month - this means that you oldest chlorine will only be at most 6 weeks old
    • Store it in a cool place - I keep mine in my basement and it keeps the chlorine at around 64 F
    30,000 gal, 20 x 40 ft vinyl, IG, installed 2006
    1 HP WhisperFlo pump, 60 sqft Pentair Quad D.E., Liquidator(8 gallon) with 3/8 upgrade, AquaVac TigerShark cleaning robot
    TFTestkits TF-100 with SpeedStir, WS
    A proud practitioner of TFP since 2013
    Jul 2015
    Coventry, CT
    22
    Great advice. Thanks. I see I could save a few bucks there. And I'll have to check out Bidwell!
    1.5hp pump
    Jul 2015
    Coventry, CT
    22
    Quote Originally Posted by YippeeSkippy View Post
    I hear you. This is my first house so money is tight. And it's my first pool ever as well so I don't really know what to expect. I literally opened this pool, my first pool, less than 2 weeks ago. I do agree 45 dollars to have a perfect pool is pretty sweet!
    1.5hp pump
    Jul 2015
    Coventry, CT
    22
    Quote Originally Posted by laprjns View Post
    • Buy only fresh chlorine - check the date lot code and buy only if it less than two week old
    • Only buy enough for a month - the means that you oldest chorine will only be at most 6 week old
    OSJL It is! Thanks for that as well. I just learned not to over buy. I think I have about 15 jugs of bleach left. I'm sure I could dig in the forums but how long is bleach or the 12.5% at ocean state good for? Or should I say how long is it effective at sanitizing a pool?
    1.5hp pump
    daleyfolk's Avatar
    Jul 2014
    Boise,Idaho
    51
    Boise Idaho here. 9 hours of sun on my 17500 gal.pool. CYA 50. I lose at least 3 ppm a day, and add a little more than half a jug per day. $1.50/day...I've stopped fretting about it...it is what it is.
    17.5 K gallons (16x32) vinyl inground pool with 1 hp pump and an old Triton sand filter. >20 years old. New 2015 Rheem gas heater. TF-100 Test kit. Little red robot and a Pool Blaster Max.
  20. Back To Top    #20
    Husky25's Avatar
    Jun 2015
    459
    Regardless of the liquid source (LC or concentrated bleach), all sodium hypochlorite (NaClO) breaks down with exposure to light and heat, but my understanding is it is a matter of percentage.
    For example, given similar conditions and treatment, it would take the NaClO in Liquid Chlorine the same amount of time to go from 12.5% to 10% concentration as it would the NAClO in Concentrated bleach to go from 8.25% to 6.6%. Less nominal loss, but still 20%. As long as there is some active ingredient remaining in the jug, it will be effective. You just have to use more, so it's not terribly efficient and the cost per ounce of active ingredient increases.
    The liquid chlorine at OSJL is pretty fresh. Every case I've bought this year has had a 2015 "born on" date. A case will last me just over a week on average.
    Chris
