Thread: Bubbles from my return
    kristenerika's Avatar
    Jul 2015
    Waco TX
    19
    Hello there. This evening I noticed that two (out of eight) of my returns have a constant stream of bubbles coming from them. One return has small bubbles, the other has teeny tiny bubbles (so small that it just looks like the water is cloudy). Everything else seems normal. What could be causing this?
    Brand new pool owner -- first day of swimming July 4, 2015! 22,000 gallon custom (14 x 40 rectangle) gunite in-ground pool with Stonescape plaster (Irish Mist). Hayward Pro Series sand filter (S244T2), Hayward TriStar pump (SP3207X10), Hayward Goldline Turbo Cell T-Cell-15 SWCG with Pro Logic control panel. Taylor K2006-C test kit. Mom to three boys, eight rescue parrots, and two dogs.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,503
    Re: Bubbles from my return
    They are from your SWG. Normal.
    Jul 2015
    Waco TX
    19
    Thank you for the quick reply!
