Results 1 to 10 of 10
Thread: 1st time pool owners, cloudy water from returns
    Jul 2015
    Jackson NJ
    7
    Hi!
    This site comes highly recommended, your reputation preceeds you!
    We bought a house in November and didn't open the pool until last week because we were waiting for our fence installation. Currently pH is 7.1. Alkaline is 45, but probably already corrected with B/W's. Chlorine a little low but was told it would be in the correct range with another shock.
    Upon initial examination I thought there was sand in the pool. After vacuuming once, and actually removing all of it, so it looked shiny and clean, the next morning the same crud was back on the bottom of the pool again. I initially thought that I wasn't careful enough in disconnecting the vacuum and I allowed debris back in. By the third vacuum I was absolutely positive that was not the case. Today I finally observed the origin of it. After vacuuming, backwashing and adding DE I turned the filter back on and saw the water coming back through the returns was cloudy. It almost looks white, like DE. I am supposed to add that into the skimmer under the basket right? Sigh. I worked so hard three times to clean the pool spic and span and with one flick of a button I trash it again. I turned the filter off and figured I'd see what you all had to say. I would be grateful, so grateful for any suggestions or advice.
    Thanks!
    Roxanne
    24-26K gal, IG concrete/plaster 08-09, DE filter, 1.5 HP, Polaris 380, well water, Jackson NJ, 1st time pool owners. Don't have all numbers. Not a multi port valve. Thanking you all in advance!
    Jun 2015
    Raleigh
    357
    Re: 1st time pool owners, cloudy water from returns
    After backwashing are you rinsing before going back to filter?
    18' x 38' Pool, 3' to 8' Depth
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Jul 2015
    Jackson NJ
    7
    Thanks Robertmee for your response.
    In my quick lesson from the man who opened the pool there was no guidance as to rinsing between backwashing and filter. I know nothing of this. What is rinsing? Rinsing what? I know that this is not a multiport valve. There is a black toggle. I raise it and turn it 180 degrees to the left for back wash. Then I add DE and turn it back to it's starting position. Am I missing this step?
    Jun 2015
    Raleigh
    357
    Ah....I wrongly assumed you had a multiport valve.
    Maybe this link will help
    How To Clean Your DE Filter - Leslies Poolapedia
    Vinyl Liner
    SWG
    Variable Speed Pump
    Sand Filter
    Jul 2015
    Jackson NJ
    7
    That's ok Robertmee! I appreciate your offer of help. That should probably be something I mentioned in my signature huh. So could it be DE? Since I am adding it right before I turn the pump back on. If it is DE, should it be coming back in via the return? Is it dangerous to swim in? I would think so. The rest of the pool water is really nice. Not "sparkly" per sae, but nice very nice.
    I just noticed your link, how to clean DE filter. Perfect! I was getting around to that begrudgingly! Going to read now.
    Jul 2015
    Jackson NJ
    7
    The only thing is this, upon opening the pool and start up we've been running at 25 psi. I don't know what is "normal" for our setup as I am not in contact with the previous owner. And that doesn't look too daunting, cleaning the filter, but I am wary of messing around with it, unless I know I definitely have to, as the clamp ring and bolt are bent. And I foresee and issue finding another as they are no longer manufactured.
    Jul 2013
    North Canton, OH
    192
    Open your DE and inspect your grids. I had a grid with a hole the size of a pencil in it. Every time I back washed the filter, when I put it back on line and added DE, the water from the returns would get cloudy, and I got DE on the floor of the pool. I replaced the grid for about $20 and it had been fine since.
    30,000 gal IG 20x40 8ft deep end vinyl liner in NE Ohio DOB Sept 2012
    Hayward 4820 DE filter, Hayward SP2610x15 1.5HP single speed pump
    Hayward H400FDN natural gas heater, Frog min'l/Cl2 system (not in use)
    autocover, Dolphin DX4 cleaner, well water, TF100 test kit
    Jul 2013
    North Canton, OH
    192
    Also, read this section in TFP about DE operation and maintenance, especially the section about proper back flush. It helped me resolve my DE issues.
    http://www.troublefreepool.com/threa...for-DE-filters
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Quote Originally Posted by Roxanne1 View Post
    can you take a picture of the filter, we are pretty good at finding things we may be able to get it fixed...
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,105
    also, you might find a useful video or two about your filter on youtube. I found mine and it helped me taking mine apart the first time.
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
