Thread: Solar cover
    May 2015
    Central PA
    38
    Solar cover
    I'm thinking of using a pool cover to help with temp and water loss. Does it help with evaporation? Can I run the filter with the cover on? Any algae concerns?
    ABG 24' Filter Cartridge 13,600 Gallons
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Solar cover
    Yes, if the pool cover is solid/not mesh. Most of the cooling occurs at night due to evaporate cooling. Yes you can run the filter with the cover on, aim jets downwards. (No skimming action will result). Maintain the correct CYA/FC ratio to avoid algae concerns.
